[PATCH] Basic lwIP for STM32H7 BSP
Joel Sherrill
joel at rtems.org
Thu Feb 4 13:39:46 UTC 2021
On Thu, Feb 4, 2021, 6:18 AM Robin Müller <robin.mueller.m at gmail.com> wrote:
> I think the DMA descriptors need to be 32 byte (0x20) aligned. That's the
> reason the example application was set up like this.
But you can just as easily turn them into pointers which point to 32 byte
aligned areas in a nocache region.
Just wondering if that's possible with the code because I think it would be
easier with the existing linkcmds to assign a nocache area as you need and
then split it by hand.
Sebastian... ?
> Kind Regards
> Robin
> On Wed, 3 Feb 2021 at 15:32, Joel Sherrill <joel at rtems.org> wrote:
>> On Wed, Feb 3, 2021, 8:26 AM Robin Müller <robin.mueller.m at gmail.com>
>> wrote:
>>> Also, Andrei Chichak provided a very good explanation:
>>> The STM32x7 ethernet controllers need their descriptors and data areas
>>>> to be located on 32-byte boundaries with a combination of cache being
>>>> turned off and buffering being turned off. This is a side effect of the
>>>> STM32x7 DMA and data caching.
>>>> The examples that ST have for LWiP under FreeRTOS have some issues with
>>>> the linker file having overlapping sections and the stack (above the ETH
>>>> data areas) being left with no cache and no buffering. The space above the
>>>> rx/tx buffers is also less than the stack space minimum specified in the
>>>> linker file as well. Some rearranging of the ETH descriptors and data
>>>> areas would be prudent. Like push them to the top of SRAM and locate the
>>>> stack below.
>>>> To get this all going, they set up the MPU for two overlapping
>>>> sections, one being the top 16kB of SRAM and the other the 256B that
>>>> contain the ETH descriptors. I believe the MPU regions can be set in
>>>> increments of 32Bytes, so setting up the cache and buffering should be
>>>> do-able without affecting the stack.
>> Just asking. Can this be a non-cacheable region and the variables not in
>> special sections? I wonder if changing them to normal pointers to special
>> memory would ripple. Do they just use the variables for initialization or
>> reference them a lot?
>> I think the standard linkcmds setup allows for nocache areas already.
>> --joel
>>> Kind Regards
>>> Robin Müller
>>> On Wed, 3 Feb 2021 at 14:50, Robin Müller <robin.mueller.m at gmail.com>
>>> wrote:
>>>> The following link contains more theoretical information about why
>>>> these sections were placed at these addresses:
>>>> https://community.st.com/s/article/FAQ-DMA-is-not-working-on-STM32H7-devices
>>>> Kind Regards
>>>> Robin
>>>> On Wed, 3 Feb 2021 at 14:44, Robin Müller <robin.mueller.m at gmail.com>
>>>> wrote:
>>>>> The DMA descriptors need to be placed at the start of the SRAM3 and
>>>>> need to be aligned in a certain way. The RX buffer will take up the first
>>>>> (slightly less than) 16 kB of SRAM3 but needs to be placed
>>>>> behind the DMA descriptors. It also needs to be placed in a way that
>>>>> the MPU configuration required for the DMA descriptors will not do
>>>>> something with the RX buffers.
>>>>> In the example provided by STM32, the first 256 bytes are configured
>>>>> by MPU Config.
>>>>> Kind Regards
>>>>> Robin
>>>>> On Wed, 3 Feb 2021 at 13:43, Sebastian Huber <
>>>>> sebastian.huber at embedded-brains.de> wrote:
>>>>>> On 02/02/2021 20:10, Robin Mueller wrote:
>>>>>> > + /* Not an ideal solution but required for lwIP on the STM32H7
>>>>>> BSP.
>>>>>> > + This places the DMA descriptors for lwIP at the start of
>>>>>> SRAM3.
>>>>>> > + The MPU still needs to be configured for the DMA descriptor
>>>>>> regions to be
>>>>>> > + bufferable, non-cacheable, non-shareable (first 256 bytes) */
>>>>>> > + .lwip_sec_stm32h7 (NOLOAD) : ALIGN_WITH_INPUT {
>>>>>> > + . = ABSOLUTE(0x30040000);
>>>>>> > + *(.RxDecripSection)
>>>>>> > + . = ABSOLUTE(0x30040060);
>>>>>> > + *(.TxDecripSection)
>>>>>> > + . = ABSOLUTE(0x30040200);
>>>>>> > + *(.RxArraySection)
>>>>>> > + } >SRAM_3 AT> REGION_TEXT_LOAD
>>>>>> This is the wrong linker command file. This stuff should be in
>>>>>> spec/build/bsps/arm/stm32h7/linkcmdsmemory.yml
>>>>>> with an output section name like ".stm32h7_sram_3" and corresponding
>>>>>> input section names. Why do you need absolute addresses here?
>>>>>> embedded brains GmbH
>>>>>> Herr Sebastian HUBER
>>>>>> Dornierstr. 4
>>>>>> 82178 Puchheim
>>>>>> Germany
>>>>>> email: sebastian.huber at embedded-brains.de
>>>>>> phone: +49-89-18 94 741 - 16
>>>>>> fax: +49-89-18 94 741 - 08
>>>>>> Registergericht: Amtsgericht München
>>>>>> Registernummer: HRB 157899
>>>>>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas
>>>>>> Dörfler
>>>>>> Unsere Datenschutzerklärung finden Sie hier:
>>>>>> https://embedded-brains.de/datenschutzerklaerung/
>>>>>> _______________________________________________
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210204/6f269ed9/attachment-0001.html>
