spcontext01 failure
Richi Dubey richidubey at gmail.com
Fri Feb 5 04:47:15 UTC 2021
Hi,
When I try to run spcontext01.exe with the master as the source and the
latest build, it fails.
I built a realview_pbx_a9_qemu bsp and ran the program using gdb and qemu
system arm.
Can someone please verify that it is actually failing on the current master?
Thanks,
Richi.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210205/ff2d3dbf/attachment.html>
