spcontext01 failure
Richi Dubey richidubey at gmail.com
Fri Feb 5 05:26:21 UTC 2021
Also, I forgot to mention that I ran the qemu system arm like this:
:~/quick-start/CurrentMaster/rtems/6/bin$ qemu-system-arm -net none
-nographic -M realview-pbx-a9 -m 256M -kernel
~/quick-start/CurrentMaster/build/bsp/arm-rtems6/c/realview_pbx_a9_qemu/testsuites/samples/unlimited.exe
-smp 4 -s -S
So I believe it is invoking the Scheduler EDF SMP to run the test. Does
this scheduler fail for spcontext01?
On Fri, Feb 5, 2021 at 10:17 AM Richi Dubey <richidubey at gmail.com> wrote:
> Hi,
> When I try to run spcontext01.exe with the master as the source and the
> latest build, it fails.
> I built a realview_pbx_a9_qemu bsp and ran the program using gdb and qemu
> system arm.
> Can someone please verify that it is actually failing on the current
> master?
> Thanks,
> Richi.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210205/8fc85047/attachment.html>
