[RTEMS 5 PATCH v2] powerpc/shared: ISA bus bridge fails to enable the openpic irq
Sun Feb 7 23:30:33 UTC 2021
On 8/2/21 9:48 am, Joel Sherrill wrote:
> Does this have a ticket for the 5 branch? :)
Yes #4233. It is in the commit message.
> Patch is ok otherwise.
> On Sun, Feb 7, 2021, 4:45 PM <chrisj at rtems.org <mailto:chrisj at rtems.org>> wrote:
>     From: Chris Johns <chrisj at rtems.org <mailto:chrisj at rtems.org>>
>     - The call to enable the openpic irq for the ISA bridge fails
>       because the IRQ used is offset by the ISA bus signals and
>       the openpic call expects an IRQ relative to its signals.
>     - Add the MVME 2600/2700 to the list of boards with an ISA bridge.
>     Closes #4233
>      bsps/powerpc/shared/irq/irq_init.c          | 2 +-
>      bsps/powerpc/shared/irq/openpic_i8259_irq.c | 2 +-
>      2 files changed, 2 insertions(+), 2 deletions(-)
>     diff --git a/bsps/powerpc/shared/irq/irq_init.c
>     b/bsps/powerpc/shared/irq/irq_init.c
>     index 1a44992a5b..1042c9d1a8 100644
>     --- a/bsps/powerpc/shared/irq/irq_init.c
>     +++ b/bsps/powerpc/shared/irq/irq_init.c
>     @@ -310,7 +310,7 @@ void BSP_rtems_irq_mng_init(unsigned cpuId)
>      #endif
>          known_cpi_isa_bridge = 1;
>     -  if ( currentBoard == MVME_2300 ) {
>     +  if ( currentBoard == MVME_2300 || currentBoard ==
>     MVME_2600_2700_W_MVME761 ) {
>          /* nothing to do for W83C553 bridge */
>     diff --git a/bsps/powerpc/shared/irq/openpic_i8259_irq.c
>     b/bsps/powerpc/shared/irq/openpic_i8259_irq.c
>     index 4a9c393f7f..513b9ac3e0 100644
>     --- a/bsps/powerpc/shared/irq/openpic_i8259_irq.c
>     +++ b/bsps/powerpc/shared/irq/openpic_i8259_irq.c
>     @@ -214,7 +214,7 @@ int BSP_setup_the_pic(rtems_irq_global_settings* config)
>           * Must enable PCI/ISA bridge IRQ
>     -       openpic_enable_irq (BSP_PCI_ISA_BRIDGE_IRQ);
>     +    openpic_enable_irq (BSP_PCI_ISA_BRIDGE_IRQ - BSP_PCI_IRQ_LOWEST_OFFSET);
>      #endif
>      #endif
>     2.24.1
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org <mailto:devel at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/devel
>     <http://lists.rtems.org/mailman/listinfo/devel>
