[RTEMS 5 PATCH v2] powerpc/shared: ISA bus bridge fails to enable the openpic irq
Joel Sherrill
joel at rtems.org
Mon Feb 8 01:23:24 UTC 2021
On Sun, Feb 7, 2021, 5:30 PM Chris Johns <chrisj at rtems.org> wrote:
> On 8/2/21 9:48 am, Joel Sherrill wrote:
> > Does this have a ticket for the 5 branch? :)
> Yes #4233. It is in the commit message.
:) Just making sure there were different ones for the five branch and the
master.
> Chris
> > Patch is ok otherwise.
> > On Sun, Feb 7, 2021, 4:45 PM <chrisj at rtems.org <mailto:chrisj at rtems.org>>
> wrote:
> > From: Chris Johns <chrisj at rtems.org <mailto:chrisj at rtems.org>>
> > - The call to enable the openpic irq for the ISA bridge fails
> > because the IRQ used is offset by the ISA bus signals and
> > the openpic call expects an IRQ relative to its signals.
> > - Add the MVME 2600/2700 to the list of boards with an ISA bridge.
> > Closes #4233
> > bsps/powerpc/shared/irq/irq_init.c | 2 +-
> > bsps/powerpc/shared/irq/openpic_i8259_irq.c | 2 +-
> > 2 files changed, 2 insertions(+), 2 deletions(-)
> > diff --git a/bsps/powerpc/shared/irq/irq_init.c
> > b/bsps/powerpc/shared/irq/irq_init.c
> > index 1a44992a5b..1042c9d1a8 100644
> > --- a/bsps/powerpc/shared/irq/irq_init.c
> > +++ b/bsps/powerpc/shared/irq/irq_init.c
> > @@ -310,7 +310,7 @@ void BSP_rtems_irq_mng_init(unsigned cpuId)
> > #endif
> > known_cpi_isa_bridge = 1;
> > - if ( currentBoard == MVME_2300 ) {
> > + if ( currentBoard == MVME_2300 || currentBoard ==
> > MVME_2600_2700_W_MVME761 ) {
> > /* nothing to do for W83C553 bridge */
> > diff --git a/bsps/powerpc/shared/irq/openpic_i8259_irq.c
> > b/bsps/powerpc/shared/irq/openpic_i8259_irq.c
> > index 4a9c393f7f..513b9ac3e0 100644
> > --- a/bsps/powerpc/shared/irq/openpic_i8259_irq.c
> > +++ b/bsps/powerpc/shared/irq/openpic_i8259_irq.c
> > @@ -214,7 +214,7 @@ int BSP_setup_the_pic(rtems_irq_global_settings*
> config)
> > * Must enable PCI/ISA bridge IRQ
> > - openpic_enable_irq (BSP_PCI_ISA_BRIDGE_IRQ);
> > + openpic_enable_irq (BSP_PCI_ISA_BRIDGE_IRQ -
> BSP_PCI_IRQ_LOWEST_OFFSET);
> > #endif
> > #endif
> > 2.24.1
> > devel mailing list
> > devel at rtems.org <mailto:devel at rtems.org>
> > <http://lists.rtems.org/mailman/listinfo/devel>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210207/0fef6f5a/attachment.html>
