Coverity Unchecked Return Value Issues
Mon Feb 8 19:52:57 UTC 2021
On Mon, Feb 8, 2021 at 11:59 AM Joel Sherrill <joel at rtems.org> wrote:
> On Mon, Feb 8, 2021 at 12:39 PM Gedare Bloom <gedare at rtems.org> wrote:
>> On Mon, Feb 8, 2021 at 11:24 AM Joel Sherrill <joel at rtems.org> wrote:
>>> Hi
>>> There are more than a couple of these. in our set of CIDs. I am
>>> wondering if these can be addressed with a macro like this:
>>> #define _IGNORED_RETURN_STATUS(_status, _ok) \
>>>   do { \
>>>     _Assert((_status) == (_ok)); \
>> Can you also pass the comparison? I guess it would usually be ==, but it
>> could be != sometimes? I think that is the main challenge here.
> How about 2 macro names? One for positive and one for negative
> _IGNORE_RETURN_STATUS_EQ
> _IGNORE_RETURN_STATUS_NEQ
> Or even _Assert_Return_status_eq and _neq. I'd like these to be candidates
> for our internal assert.h
I prefer to use the assert part. The wording is a little awkward. I guess
it doesn't hurt to put the (void) (_status); and still use the status
later? so we don't have to specifically indicate ignored/unused in the
macro name?
Then:
_Assert_Return_value_equals(_return_value, _expected_value)
_Assert_Return_not_equals(_return_value, _not_expected_value)
or so would be my preference.
We should also have
RTEMS_IGNORE_RETURN_VALUE(_return_value)
maybe.
> It will end up being three arguments otherwise. It would be nice to keep
> it reliably to one line.
Embedding the condition in the name will be easier to spot check anyway.
(Like catch == vs = problem)
>>>    (void) (_status);
>>>   } while (0);
>>> Or _Assert_Ignored_return?
>>> The ones I have looked at, the return value should always be successful
>>> but there isn't any reason we can't be defensive about them.
>>> Thoughts.
>>> --joel
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210208/54591f2f/attachment-0001.html>
