[PATCH] basedefs: Add stringification of argument lists
Tue Feb 9 09:20:58 UTC 2021
Hello Frank,
On 09/02/2021 10:12, Frank Kühndel wrote:
> No objections but I am missing something. We do not used a certain
> frozen RTEMS version for the pre-qualification, do we?
we definitely don't use a frozen RTEMS version for the pre-qualification.
> This brings about the problem that very change in RTEMS which is part of
> the pre-qualified source code must trigger the needed changes in the
> pre-qualification data set - here in the specification items:
>    spec/rtems/basedefs/req/string-0.yml
>    spec/rtems/basedefs/req/xstring-0.yml
> I know, everyone wants to program and push his/her code into RTEMS as
> fast as possible without dealing with documentation, specification items
> or other depending stuff. ... and I am among the first doing so ...
> Yet, if the pre-qualification data set is not continuously kept up to
> date, the whole documentation is outdated even before the
> pre-qualification project ends. Is this topic somehow addressed? ... and
> who is responsible to adapt the above two files?
We are responsible to monitor the RTEMS development during the
pre-qualification activity and adjust the specification, etc. I would
have sent you an e-mail that a specification update is necessary. The
basedefs is an area with a higher probability of changes.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
