[PATCH] basedefs: Add stringification of argument lists
Gedare Bloom
gedare at rtems.org
Tue Feb 9 14:04:04 UTC 2021
On Tue, Feb 9, 2021 at 2:46 AM Sebastian Huber
> Hello Frank,
> On 09/02/2021 10:12, Frank Kühndel wrote:
> > No objections but I am missing something. We do not used a certain
> > frozen RTEMS version for the pre-qualification, do we?
> we definitely don't use a frozen RTEMS version for the pre-qualification.
> > This brings about the problem that very change in RTEMS which is part of
> > the pre-qualified source code must trigger the needed changes in the
> > pre-qualification data set - here in the specification items:
> > spec/rtems/basedefs/req/string-0.yml
> > spec/rtems/basedefs/req/xstring-0.yml
> > I know, everyone wants to program and push his/her code into RTEMS as
> > fast as possible without dealing with documentation, specification items
> > or other depending stuff. ... and I am among the first doing so ...
> > Yet, if the pre-qualification data set is not continuously kept up to
> > date, the whole documentation is outdated even before the
> > pre-qualification project ends. Is this topic somehow addressed? ... and
> > who is responsible to adapt the above two files?
> We are responsible to monitor the RTEMS development during the
> pre-qualification activity and adjust the specification, etc. I would
> have sent you an e-mail that a specification update is necessary. The
> basedefs is an area with a higher probability of changes.
Is there a sustainable plan for beyond the project lifetime (maybe,
something we need to discuss separately)? Is there a plan/way to
automate consistency checking or to clue a developer that there is a
possible related spec file to consider updating?
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
