Question regarding RSB and open projects
    Eshan Dhawan
    eshandhawan51 at gmail.com
    Tue Feb  9 19:33:57 UTC 2021
Hi ayushman
It looks you didn't install all the dependencies required
check this :
https://docs.rtems.org/branches/master/user/hosts/posix.html#linux
On Wed, Feb 10, 2021 at 12:58 AM Ayushman Mishra <ayushvidushi01 at gmail.com>
wrote:
> Ayusman Mishra
> 1. I was going through ticket #4145
> (https://devel.rtems.org/ticket/4145) and tried building bsp on rtems6
> and rtems5 both using rsb
> https://docs.rtems.org/branches/master/user/start/bsp-build.html#rsb-bsp-build
> but got Build FAILED (it says pax is missing (configure: error: pax is
> missing.), I have attached full error report txt file). However I did
> build bsp erc32 and pc386 using rsb on rtems5 (first .bootstrap -c
> sb-bootstrap then used configure file
> ($HOME/development/rtems/rtems-5/configure --target=i386-rtems5
> --enable-rtemsbsp=pc386 )) on rtems6 there is no sb-bootstrap file or
> configure file present/made.
> I wanted to know is there anyway of using RSB on rtems6.
> Also while building different bsp toolsets for rtems (erc32/pc386) I
> used rtems on 2 different directories , Is there any way of building
> different BSPs on same rtems?
> 2. I went through list of open projects and found projects related to
> testing and development of ecosystem quite interesting,
> #3710 https://devel.rtems.org/ticket/3710
> #3860 https://devel.rtems.org/ticket/3860
> #3892 https://devel.rtems.org/ticket/3892
> I would be very grateful to know if any of the above projects is open
> for participation and if yes then work done/needed to be done in it.
> devel mailing list
> devel at rtems.org
Thanks
- Eshan
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210210/c53f1745/attachment.html>
