Question regarding RSB and open projects
Ayushman Mishra ayushvidushi01 at gmail.com
Wed Feb 10 05:06:43 UTC 2021
Thanks for the help Eshan but actually I have already performed this
step (sudo apt-get build-dep build-essential gcc-defaults g++ gdb git
unzip pax bison flex texinfo unzip python3-dev libpython-dev \
libncurses5-dev zlib1g-dev) , here since my system was not able to
find libpython-dev (Unable to find a source package for libpython-dev
) so i used libpython2.7-dev , I tried with both python2-dev and python3-dev
 sudo apt-get build-dep build-essential gcc-defaults g++ gdb git \
unzip pax bison flex texinfo unzip python2-dev libpython2.7-dev \
Reading package lists... Done
Picking 'gcc-defaults' as source package instead of 'g++'
Picking 'python-defaults' as source package instead of 'python2-dev'
Picking 'python2.7' as source package instead of 'libpython2.7-dev'
Picking 'ncurses' as source package instead of 'libncurses5-dev'
Picking 'zlib' as source package instead of 'zlib1g-dev'
Building dependency tree
Reading state information... Done
0 upgraded, 0 newly installed, 0 to remove and 184 not upgraded.
but then also same Build FAILED error comes up (configure: error: pax
is missing) . Also I wanted to know does the rsb in rtems6 uses
autoconf-based build system , since there is no configure file made
and used.
On Wed, Feb 10, 2021 at 1:04 AM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> Hi ayushman
> It looks you didn't install all the dependencies required
> check this : https://docs.rtems.org/branches/master/user/hosts/posix.html#linux
> On Wed, Feb 10, 2021 at 12:58 AM Ayushman Mishra <ayushvidushi01 at gmail.com> wrote:
>> Ayusman Mishra
>> 1. I was going through ticket #4145
>> (https://devel.rtems.org/ticket/4145) and tried building bsp on rtems6
>> and rtems5 both using rsb
>> (https://docs.rtems.org/branches/master/user/start/bsp-build.html#rsb-bsp-build)
>> but got Build FAILED (it says pax is missing (configure: error: pax is
>> missing.), I have attached full error report txt file). However I did
>> build bsp erc32 and pc386 using rsb on rtems5 (first .bootstrap -c
>> sb-bootstrap then used configure file
>> ($HOME/development/rtems/rtems-5/configure --target=i386-rtems5
>> --enable-rtemsbsp=pc386 )) on rtems6 there is no sb-bootstrap file or
>> configure file present/made.
>> I wanted to know is there anyway of using RSB on rtems6.
>> Also while building different bsp toolsets for rtems (erc32/pc386) I
>> used rtems on 2 different directories , Is there any way of building
>> different BSPs on same rtems?
>> 2. I went through list of open projects and found projects related to
>> testing and development of ecosystem quite interesting,
>> #3710 https://devel.rtems.org/ticket/3710
>> #3860 https://devel.rtems.org/ticket/3860
>> #3892 https://devel.rtems.org/ticket/3892
>> I would be very grateful to know if any of the above projects is open
>> for participation and if yes then work done/needed to be done in it.
>> devel mailing list
>> devel at rtems.org
> Thanks
> - Eshan
