Question regarding RSB and open projects
Gedare Bloom
gedare at rtems.org
Tue Feb 9 22:03:13 UTC 2021
On Tue, Feb 9, 2021 at 2:34 PM Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Feb 9, 2021 at 1:28 PM Ayushman Mishra <ayushvidushi01 at gmail.com>
> wrote:
>> Ayusman Mishra
>> 1. I was going through ticket #4145
>> (https://devel.rtems.org/ticket/4145) and tried building bsp on rtems6
>> and rtems5 both using rsb
>> https://docs.rtems.org/branches/master/user/start/bsp-build.html#rsb-bsp-build
>> but got Build FAILED (it says pax is missing (configure: error: pax is
>> missing.), I have attached full error report txt file). However I did
>> build bsp erc32 and pc386 using rsb on rtems5 (first .bootstrap -c
>> sb-bootstrap then used configure file
>> ($HOME/development/rtems/rtems-5/configure --target=i386-rtems5
>> --enable-rtemsbsp=pc386 )) on rtems6 there is no sb-bootstrap file or
>> configure file present/made.
>> I wanted to know is there anyway of using RSB on rtems6.
>> Also while building different bsp toolsets for rtems (erc32/pc386) I
>> used rtems on 2 different directories , Is there any way of building
>> different BSPs on same rtems?
>> 2. I went through list of open projects and found projects related to
>> testing and development of ecosystem quite interesting,
>> #3710 https://devel.rtems.org/ticket/3710
> I recently added Automated Coverity runs. We haven't figured out how to
> scrape the coverity website and turn it into open information. I have
> exported
> the data they have but it isn't enough to be actionable. If you have some
> creative ideas here, it would be great.
> Coverity is being run once a day if needed so that side of automating is
> done.
We have a modeling file. It's not clear to me if we can/should add to it to
further reduce any false positives. Improving just the modeling file is not
really a GSoC-worthy project, although it could be in scope for a broader
Coverity-related project, perhaps one that creates a tool to help port
Coverity defects from Scan into Trac tickets.
>> #3860 https://devel.rtems.org/ticket/3860
> You should ask about Code Style Checking in thread by itself. Sebastian
> has made progress with one formatter and there needs to be an evaluation
> of how much source code can be run through that reformatter unchanged.
> If it changes anything, is this an adjustment to match our style or
> something
> we want to accept as a necessary evil of using the formatter.
> When we have a combination or either accepting their format changes and
> ideal configuration settings, carefully working through the source owned
> by the RTEMS Project is the next step.
> And then figuring out how to make it a part of the development process
> and patch review.
> This should have a lot of work and have a good impact on the project.
>> #3892 https://devel.rtems.org/ticket/3892
> I am not the Python expert to comment on this. I think there has been
> acceptance that some code needs to be Python2 and some can be
> Python3. I think we may have agreed on Python style (to some extent)
> so the previous style project has similar work here.
> But pytest support is an unknown to me.
> This would be good one to start a new thread with so the Python
> experts from RTEMS speak up.
>> I would be very grateful to know if any of the above projects is open
>> for participation and if yes then work done/needed to be done in it.
> There is probably more work in the latter two.
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210209/9cade5e6/attachment-0001.html>
