[PATCH 0/8] Generate documentation for managers
Wed Feb 10 16:10:50 UTC 2021
Hello Frank,
thanks for the review.
On 10/02/2021 11:35, Frank Kühndel wrote:
> Hello Sebastian,
> this actually really improves the documentation. The new constraints
> sections makes it clearer when a function can be used. Moreover, there
> are new descriptions of all parameters. I guess you must have looked in
> the source code, to figure out the correct set of errors each directive
> may return. I also did see that there are new code examples. Like it!
> I only fond these minor issues:
> 1) In section "SEMAPHORE_CREATE - Create a semaphore" it looks like the
> following passage for the original text has not found its way into the
> new description:
> -    It is not allowed to create an initially locked MrsP semaphore and the
> -    ``RTEMS_INVALID_NUMBER`` status code will be returned in SMP
> configurations
> -    in this case.  This prevents lock order reversal problems with the
> -    allocator mutex.
Good catch, this error still exists in the code, however, I think it can
be removed. I will have a look at it.
> 2) In section "rtems_extension_create()": The parameter
> "extension_table" is not described in the parameter list. It also does
> not get clear to me from the description what is the use of the whole
> thing/what happens here with the "extension_table". The original text
> had at least this sentence: "The extension set specified by
> :c:data:`table` is copied to the ESCB." -- what ever that means.
I added a description, the extension sets are described in the
background section of the chapter.
> Greetings
> fk
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
