[PATCH v2 05/12] c-user: Clarify object services documentation
Sebastian Huber
Wed Feb 10 16:28:02 UTC 2021
Unify the wording across similar directives of other managers.
Update #3993.
c-user/object-services/directives.rst | 12 ++++++------
1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/c-user/object-services/directives.rst b/c-user/object-services/directives.rst
index 19d4d82..54f234f 100644
--- a/c-user/object-services/directives.rst
+++ b/c-user/object-services/directives.rst
@@ -168,9 +168,9 @@ Gets the object name associated with the object identifier.
This parameter is the object identifier to get the name.
``name``
- This parameter is the pointer to an object name variable. The object name
- associated with the object identifier will be stored in this variable, in
- case of a successful operation.
+ This parameter is the pointer to an object name variable. When the
+ directive call is successful, the object name associated with the object
+ identifier will be stored in this variable.
.. rubric:: RETURN VALUES:
@@ -801,9 +801,9 @@ Gets the object class information of the object class of the object API.
information.
``info``
- This parameter is the pointer to an object class information variable. The
- object class information of the class of the API will be stored in this
- variable, in case of a successful operation.
+ This parameter is the pointer to an object class information variable.
+ When the directive call is successful, the object class information of the
+ class of the API will be stored in this variable.
2.26.2
