[PATCH v2 06/12] c-user: Add labels to the manager chapters
Sebastian Huber
Wed Feb 10 16:28:03 UTC 2021
Update #3993.
c-user/board_support_packages.rst | 2 +-
c-user/clock/index.rst | 2 ++
c-user/config/scheduler-general.rst | 2 +-
c-user/dual-ported-memory/index.rst | 2 ++
c-user/event/index.rst | 2 ++
c-user/interrupt/index.rst | 2 ++
c-user/io/index.rst | 2 ++
c-user/message/index.rst | 2 ++
c-user/object-services/index.rst | 2 ++
c-user/partition/index.rst | 2 ++
c-user/rate-monotonic/index.rst | 2 ++
c-user/region/index.rst | 2 ++
c-user/scheduling-concepts/index.rst | 2 +-
c-user/semaphore/index.rst | 2 ++
c-user/signal/index.rst | 2 ++
c-user/task/index.rst | 2 ++
c-user/user-extensions/index.rst | 2 +-
17 files changed, 30 insertions(+), 4 deletions(-)
diff --git a/c-user/board_support_packages.rst b/c-user/board_support_packages.rst
index e163190..4e1c991 100644
--- a/c-user/board_support_packages.rst
+++ b/c-user/board_support_packages.rst
@@ -205,7 +205,7 @@ deallocating the context area, the task initiation and reinitiation extensions
would be responsible for priming the context area, and the task context switch
extension would save and restore the context of the device.
-For more information on user extensions, refer to :ref:`User Extensions Manager`.
+For more information on user extensions, refer to :ref:`RTEMSAPIClassicUserext`.
Multiprocessor Communications Interface (MPCI)
diff --git a/c-user/clock/index.rst b/c-user/clock/index.rst
index 010299f..11f2790 100644
--- a/c-user/clock/index.rst
+++ b/c-user/clock/index.rst
@@ -4,6 +4,8 @@
.. index:: clock
+.. _RTEMSAPIClassicClock:
Clock Manager
diff --git a/c-user/config/scheduler-general.rst b/c-user/config/scheduler-general.rst
index 7bdd044..cbdb145 100644
--- a/c-user/config/scheduler-general.rst
+++ b/c-user/config/scheduler-general.rst
@@ -38,7 +38,7 @@ than one, then the
:ref:`SchedulerSMPEDF`
is selected as the default scheduler algorithm.
-For the schedulers provided by RTEMS (see :ref:`SchedulingConcepts`), the
+For the schedulers provided by RTEMS (see :ref:`RTEMSAPIClassicScheduler`), the
configuration is straightforward. All that is required is to define the
configuration option which specifies which scheduler you want for in your
application.
diff --git a/c-user/dual-ported-memory/index.rst b/c-user/dual-ported-memory/index.rst
index 07628ce..cc114ac 100644
--- a/c-user/dual-ported-memory/index.rst
+++ b/c-user/dual-ported-memory/index.rst
@@ -5,6 +5,8 @@
.. index:: ports
.. index:: dual ported memory
+.. _RTEMSAPIClassicDPMem:
Dual-Ported Memory Manager
diff --git a/c-user/event/index.rst b/c-user/event/index.rst
index 6503c35..17ccfbc 100644
--- a/c-user/event/index.rst
+++ b/c-user/event/index.rst
@@ -4,6 +4,8 @@
.. index:: events
+.. _RTEMSAPIClassicEvent:
Event Manager
diff --git a/c-user/interrupt/index.rst b/c-user/interrupt/index.rst
index e1c529e..d3e4429 100644
--- a/c-user/interrupt/index.rst
+++ b/c-user/interrupt/index.rst
@@ -4,6 +4,8 @@
.. index:: interrupts
+.. _RTEMSAPIClassicIntr:
Interrupt Manager
diff --git a/c-user/io/index.rst b/c-user/io/index.rst
index 0b6ff6f..424c776 100644
--- a/c-user/io/index.rst
+++ b/c-user/io/index.rst
@@ -5,6 +5,8 @@
.. index:: device drivers
.. index:: IO Manager
+.. _RTEMSAPIClassicIO:
I/O Manager
diff --git a/c-user/message/index.rst b/c-user/message/index.rst
index 456d177..92ebdae 100644
--- a/c-user/message/index.rst
+++ b/c-user/message/index.rst
@@ -5,6 +5,8 @@
.. index:: messages
.. index:: message queues
+.. _RTEMSAPIClassicMessage:
Message Manager
diff --git a/c-user/object-services/index.rst b/c-user/object-services/index.rst
index 878e47b..43a2c10 100644
--- a/c-user/object-services/index.rst
+++ b/c-user/object-services/index.rst
@@ -4,6 +4,8 @@
.. index:: object manipulation
+.. _RTEMSAPIClassicObject:
Object Services
diff --git a/c-user/partition/index.rst b/c-user/partition/index.rst
index c8e7348..1396e5c 100644
--- a/c-user/partition/index.rst
+++ b/c-user/partition/index.rst
@@ -4,6 +4,8 @@
.. index:: partitions
+.. _RTEMSAPIClassicPart:
Partition Manager
diff --git a/c-user/rate-monotonic/index.rst b/c-user/rate-monotonic/index.rst
index 44a5765..a703ca0 100644
--- a/c-user/rate-monotonic/index.rst
+++ b/c-user/rate-monotonic/index.rst
@@ -5,6 +5,8 @@
.. index:: rate mononitonic tasks
.. index:: periodic tasks
+.. _RTEMSAPIClassicRatemon:
Rate Monotonic Manager
diff --git a/c-user/region/index.rst b/c-user/region/index.rst
index 90560a8..f0be2f7 100644
--- a/c-user/region/index.rst
+++ b/c-user/region/index.rst
@@ -4,6 +4,8 @@
.. index:: regions
+.. _RTEMSAPIClassicRegion:
Region Manager
diff --git a/c-user/scheduling-concepts/index.rst b/c-user/scheduling-concepts/index.rst
index 6d06d91..6b16f1b 100644
--- a/c-user/scheduling-concepts/index.rst
+++ b/c-user/scheduling-concepts/index.rst
@@ -5,7 +5,7 @@
.. index:: scheduling
.. index:: task scheduling
-.. _SchedulingConcepts:
+.. _RTEMSAPIClassicScheduler:
Scheduling Concepts
diff --git a/c-user/semaphore/index.rst b/c-user/semaphore/index.rst
index 2110744..c281104 100644
--- a/c-user/semaphore/index.rst
+++ b/c-user/semaphore/index.rst
@@ -7,6 +7,8 @@
.. index:: counting semaphores
.. index:: mutual exclusion
+.. _RTEMSAPIClassicSemaphore:
Semaphore Manager
diff --git a/c-user/signal/index.rst b/c-user/signal/index.rst
index ad28b9f..e418491 100644
--- a/c-user/signal/index.rst
+++ b/c-user/signal/index.rst
@@ -4,6 +4,8 @@
.. index:: signals
+.. _RTEMSAPIClassicSignal:
Signal Manager
diff --git a/c-user/task/index.rst b/c-user/task/index.rst
index f4edd40..2ce8edb 100644
--- a/c-user/task/index.rst
+++ b/c-user/task/index.rst
@@ -4,6 +4,8 @@
.. index:: tasks
+.. _RTEMSAPIClassicTask:
Task Manager
diff --git a/c-user/user-extensions/index.rst b/c-user/user-extensions/index.rst
index 294fcac..56aa9c4 100644
--- a/c-user/user-extensions/index.rst
+++ b/c-user/user-extensions/index.rst
@@ -4,7 +4,7 @@
.. index:: user extensions
-.. _User Extensions Manager:
+.. _RTEMSAPIClassicUserext:
2.26.2
