[PATCH v2 00/12] Generate documentation for managers
Gedare Bloom
gedare at rtems.org
Wed Feb 10 16:42:10 UTC 2021
Is (will be) there a section to explain the Constraints and how to
interpret them? Mainly, what kind of constraints are specified, and what
should be assumed (like, if a directive does not say it can be called from
thread context, then it implicitly cannot)?
On Wed, Feb 10, 2021 at 9:28 AM Sebastian Huber <
> This patch adds the next round of generated documentation. Patches 1 to
> 5 try to unify the documentation accross managers. The other patches
> add the generated documentation for the Semaphore, Barrier, User
> Extensions, and Clock Managers.
> Here is the updated document for review:
> https://ftp.rtems.org/pub/rtems/people/sebh/c-user.pdf
> v2:
> - Use EARS syntax for pointer parameters.
> - Document MrsP semaphore constraint
> - Document extension set parameter
> - Generate clock manager documentation
> Sebastian Huber (12):
> c-user: Clarify timer manager documentation
> c-user: Clarify event manager documentation
> c-user: Clarify partition manager documentation
> c-user: Clarify IO manager documentation
> c-user: Clarify object services documentation
> c-user: Add labels to the manager chapters
> c-user: Add control block acronyms
> c-user: Move deprecated/removed directives
> c-user: Generate semaphore manager documentation
> c-user: Generate barrier manager documentation
> c-user: Generate user extensions manager docs
> c-user: Generate clock manager documentation
> c-user/barrier/directives.rst | 566 +++++----
> c-user/barrier/index.rst | 2 +
> c-user/barrier/introduction.rst | 45 +-
> c-user/board_support_packages.rst | 2 +-
> c-user/clock/directives.rst | 874 +++++++------
> c-user/clock/index.rst | 3 +
> c-user/clock/introduction.rst | 83 +-
> c-user/clock/removed-directives.rst | 81 ++
> c-user/config/scheduler-general.rst | 2 +-
> c-user/dual-ported-memory/index.rst | 2 +
> c-user/event/directives.rst | 57 +-
> c-user/event/index.rst | 2 +
> c-user/event/introduction.rst | 2 +-
> c-user/glossary.rst | 67 +-
> c-user/interrupt/index.rst | 2 +
> c-user/io/directives.rst | 6 +-
> c-user/io/index.rst | 2 +
> c-user/message/index.rst | 2 +
> c-user/object-services/directives.rst | 12 +-
> c-user/object-services/index.rst | 2 +
> c-user/partition/directives.rst | 24 +-
> c-user/partition/index.rst | 2 +
> c-user/rate-monotonic/index.rst | 2 +
> c-user/region/index.rst | 2 +
> c-user/scheduling-concepts/index.rst | 2 +-
> c-user/semaphore/directives.rst | 1485 ++++++++++++++---------
> c-user/semaphore/index.rst | 2 +
> c-user/semaphore/introduction.rst | 52 +-
> c-user/signal/index.rst | 2 +
> c-user/task/deprecated-directives.rst | 46 +
> c-user/task/index.rst | 4 +
> c-user/task/removed-directives.rst | 283 +++++
> c-user/timer/directives.rst | 212 +++-
> c-user/timer/index.rst | 2 +
> c-user/timer/introduction.rst | 2 +-
> c-user/user-extensions/directives.rst | 330 +++--
> c-user/user-extensions/index.rst | 2 +-
> c-user/user-extensions/introduction.rst | 36 +-
> 38 files changed, 2913 insertions(+), 1391 deletions(-)
> create mode 100644 c-user/clock/removed-directives.rst
> create mode 100644 c-user/task/deprecated-directives.rst
> create mode 100644 c-user/task/removed-directives.rst
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210210/9e296bef/attachment-0001.html>
