[PATCH v2 12/12] c-user: Generate clock manager documentation
Wed Feb 17 16:56:07 UTC 2021
On 11/02/2021 14:31, Frank Kühndel wrote:
>> +    rtems_status_code rtems_clock_set( const rtems_time_of_day *time );
> A comment only: The above is a change in the signature of the function
> (adding `const`). Not that I object to it - on the contrary. Yet, it may
> break existing code (e.g. code which uses function pointers to
> rtems_clock_set() maybe). Not sure how the project deals with such
> changes in the API.
It is good to notice this. In this case, it is just a documentation fix
thanks to the generated content. The API change was in RTEMS 4.11.
> Note: You renamed this parameter to `time` but you renamed the parameter
> of rtems_clock_get_tod() to `time_of_day`.
I will change both parameters to time_of_day.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
