Question regarding RSB and open projects
Ayushman Mishra
ayushvidushi01 at gmail.com
Wed Feb 10 18:56:45 UTC 2021
I tested the environment ./source-builder/sb-check , it gave this
result: RTEMS Source Builder - Check, 6 (61dcadee0825)
Environment is ok
When I used ../source-builder/sb-set-builder
--prefix=/home/ayush/quickstart1/rtems/6 --target=sparc-rtems6
--with-rtems-bsp=erc32 --with-rtems-tests=yes 6/rtems-sparc , it
started rebuilding and installing rtems-sparc tool suite ( just like
it did with this ../source-builder/sb-set-builder
--prefix=$HOME/quick-start/rtems/5 5/rtems-sparc , and took same
amount of time to complete the process) but no erc32 bsp was installed
( bsp test said error: no executables supplied) , and using
6/rtems-kernel instead of 6/rtems-sparc it gives same Build error (pax
is missing) , right now rsb is only working properly for rtems5 and
not rtems6 on my system.
On Wed, Feb 10, 2021 at 11:44 AM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> On Wed, Feb 10, 2021 at 10:36 AM Ayushman Mishra <ayushvidushi01 at gmail.com> wrote:
>> Thanks for the help Eshan but actually I have already performed this
>> step (sudo apt-get build-dep build-essential gcc-defaults g++ gdb git
>> unzip pax bison flex texinfo unzip python3-dev libpython-dev \
>> libncurses5-dev zlib1g-dev) , here since my system was not able to
>> find libpython-dev (Unable to find a source package for libpython-dev
>> ) so i used libpython2.7-dev , I tried with both python2-dev and python3-dev
>> sudo apt-get build-dep build-essential gcc-defaults g++ gdb git \
>> unzip pax bison flex texinfo unzip python2-dev libpython2.7-dev \
>> Reading package lists... Done
>> Picking 'gcc-defaults' as source package instead of 'g++'
>> Picking 'python-defaults' as source package instead of 'python2-dev'
>> Picking 'python2.7' as source package instead of 'libpython2.7-dev'
>> Picking 'ncurses' as source package instead of 'libncurses5-dev'
>> Picking 'zlib' as source package instead of 'zlib1g-dev'
>> Building dependency tree
>> Reading state information... Done
>> 0 upgraded, 0 newly installed, 0 to remove and 184 not upgraded.
> did you test the environment
>> but then also same Build FAILED error comes up (configure: error: pax
>> is missing) . Also I wanted to know does the rsb in rtems6 uses
>> autoconf-based build system , since there is no configure file made
>> and used.
> Also, try using
> ../source-builder/sb-set-builder --prefix=/home/ayush/quickstart1/rtems/6 --target=sparc-rtems6 --with-rtems-bsp=erc32 --with-rtems-tests=yes 6/rtems-sparc
>> On Wed, Feb 10, 2021 at 1:04 AM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>> > Hi ayushman
>> > It looks you didn't install all the dependencies required
>> > check this : https://docs.rtems.org/branches/master/user/hosts/posix.html#linux
>> > On Wed, Feb 10, 2021 at 12:58 AM Ayushman Mishra <ayushvidushi01 at gmail.com> wrote:
>> >> Ayusman Mishra
>> >> 1. I was going through ticket #4145
>> >> (https://devel.rtems.org/ticket/4145) and tried building bsp on rtems6
>> >> and rtems5 both using rsb
>> >> (https://docs.rtems.org/branches/master/user/start/bsp-build.html#rsb-bsp-build)
>> >> but got Build FAILED (it says pax is missing (configure: error: pax is
>> >> missing.), I have attached full error report txt file). However I did
>> >> build bsp erc32 and pc386 using rsb on rtems5 (first .bootstrap -c
>> >> sb-bootstrap then used configure file
>> >> ($HOME/development/rtems/rtems-5/configure --target=i386-rtems5
>> >> --enable-rtemsbsp=pc386 )) on rtems6 there is no sb-bootstrap file or
>> >> configure file present/made.
>> >> I wanted to know is there anyway of using RSB on rtems6.
>> >> Also while building different bsp toolsets for rtems (erc32/pc386) I
>> >> used rtems on 2 different directories , Is there any way of building
>> >> different BSPs on same rtems?
>> >> 2. I went through list of open projects and found projects related to
>> >> testing and development of ecosystem quite interesting,
>> >> #3710 https://devel.rtems.org/ticket/3710
>> >> #3860 https://devel.rtems.org/ticket/3860
>> >> #3892 https://devel.rtems.org/ticket/3892
>> >> I would be very grateful to know if any of the above projects is open
>> >> for participation and if yes then work done/needed to be done in it.
>> >> _______________________________________________
>> >> devel mailing list
>> >> devel at rtems.org
>> >> http://lists.rtems.org/mailman/listinfo/devel
>> > Thanks
>> > - Eshan
