Question regarding RSB and open projects
Eshan Dhawan
eshandhawan51 at gmail.com
Wed Feb 10 06:13:59 UTC 2021
On Wed, Feb 10, 2021 at 10:36 AM Ayushman Mishra <ayushvidushi01 at gmail.com>
wrote:
> Thanks for the help Eshan but actually I have already performed this
> step (sudo apt-get build-dep build-essential gcc-defaults g++ gdb git
> unzip pax bison flex texinfo unzip python3-dev libpython-dev \
> libncurses5-dev zlib1g-dev) , here since my system was not able to
> find libpython-dev (Unable to find a source package for libpython-dev
> ) so i used libpython2.7-dev , I tried with both python2-dev and
> python3-dev
> sudo apt-get build-dep build-essential gcc-defaults g++ gdb git \
> unzip pax bison flex texinfo unzip python2-dev libpython2.7-dev \
> Reading package lists... Done
> Picking 'gcc-defaults' as source package instead of 'g++'
> Picking 'python-defaults' as source package instead of 'python2-dev'
> Picking 'python2.7' as source package instead of 'libpython2.7-dev'
> Picking 'ncurses' as source package instead of 'libncurses5-dev'
> Picking 'zlib' as source package instead of 'zlib1g-dev'
> Building dependency tree
> Reading state information... Done
> 0 upgraded, 0 newly installed, 0 to remove and 184 not upgraded.
did you test the environment
./source-builder/sb-check
but then also same Build FAILED error comes up (configure: error: pax
> is missing) . Also I wanted to know does the rsb in rtems6 uses
> autoconf-based build system , since there is no configure file made
> and used.
Also, try using
../source-builder/sb-set-builder
--prefix=/home/ayush/quickstart1/rtems/6 --target=sparc-rtems6
--with-rtems-bsp=erc32 --with-rtems-tests=yes 6/rtems-sparc
> On Wed, Feb 10, 2021 at 1:04 AM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
> > Hi ayushman
> > It looks you didn't install all the dependencies required
> > check this :
> https://docs.rtems.org/branches/master/user/hosts/posix.html#linux
> > On Wed, Feb 10, 2021 at 12:58 AM Ayushman Mishra <
> ayushvidushi01 at gmail.com> wrote:
> >> Ayusman Mishra
> >> 1. I was going through ticket #4145
> >> (https://devel.rtems.org/ticket/4145) and tried building bsp on rtems6
> >> and rtems5 both using rsb
> https://docs.rtems.org/branches/master/user/start/bsp-build.html#rsb-bsp-build
> >> but got Build FAILED (it says pax is missing (configure: error: pax is
> >> missing.), I have attached full error report txt file). However I did
> >> build bsp erc32 and pc386 using rsb on rtems5 (first .bootstrap -c
> >> sb-bootstrap then used configure file
> >> ($HOME/development/rtems/rtems-5/configure --target=i386-rtems5
> >> --enable-rtemsbsp=pc386 )) on rtems6 there is no sb-bootstrap file or
> >> configure file present/made.
> >> I wanted to know is there anyway of using RSB on rtems6.
> >> Also while building different bsp toolsets for rtems (erc32/pc386) I
> >> used rtems on 2 different directories , Is there any way of building
> >> different BSPs on same rtems?
> >> 2. I went through list of open projects and found projects related to
> >> testing and development of ecosystem quite interesting,
> >> #3710 https://devel.rtems.org/ticket/3710
> >> #3860 https://devel.rtems.org/ticket/3860
> >> #3892 https://devel.rtems.org/ticket/3892
> >> I would be very grateful to know if any of the above projects is open
> >> for participation and if yes then work done/needed to be done in it.
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> > Thanks
> > - Eshan
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210210/45dcb6f1/attachment.html>
