[PATCH 4/4] rtems-debugger-target.c: Fix Coverity Dereference before null check
Gedare Bloom
gedare at rtems.org
Thu Feb 11 21:16:52 UTC 2021
On Thu, Feb 11, 2021 at 2:00 PM Chris Johns <chrisj at rtems.org> wrote:
> On 12/2/21 7:27 am, Ryan Long wrote:
> > Fixes CID #1468682 where target is dereferenced before it has been
> > checked as to whether it is null or not in the
> > rtems_debugger_target_swbreak_control function.
> > cpukit/libdebugger/rtems-debugger-target.c | 5 +++--
> > 1 file changed, 3 insertions(+), 2 deletions(-)
> > diff --git a/cpukit/libdebugger/rtems-debugger-target.c b/cpukit/libdebugger/rtems-debugger-target.c
> > index e495170..3726a6c 100644
> > --- a/cpukit/libdebugger/rtems-debugger-target.c
> > +++ b/cpukit/libdebugger/rtems-debugger-target.c
> > @@ -171,17 +171,18 @@ int
> > rtems_debugger_target_swbreak_control(bool insert, DB_UINT addr, DB_UINT kind)
> > rtems_debugger_target* target = rtems_debugger->target;
> > - rtems_debugger_target_swbreak* swbreaks = target->swbreaks.block;
> > size_t swbreak_size;
> > uint8_t* loc = (void*) addr;
> > size_t i;
> > int r;
> > - if (target == NULL || swbreaks == NULL || kind != target->breakpoint_size) {
> > + if (target == NULL || target->swbreaks.block == NULL ||
> > + kind != target->breakpoint_size) {
> > errno = EIO;
> > return -1;
> > + rtems_debugger_target_swbreak* swbreaks = target->swbreaks.block;
> The debug server does not declare local vars in the body of functions. I would
> prefer the this code base stays that way if that is OK?
Good catch. This is a holdover from ANSI C that we should generally
adhere to in RTEMS cpukit code for historical reasons.
> Chris
> > swbreak_size =
> > sizeof(rtems_debugger_target_swbreak) + target->breakpoint_size;
> devel mailing list
> devel at rtems.org
