[PATCH 4/4] rtems-debugger-target.c: Fix Coverity Dereference before null check
Chris Johns
chrisj at rtems.org
Thu Feb 11 21:28:48 UTC 2021
On 12/2/21 8:16 am, Gedare Bloom wrote:
> On Thu, Feb 11, 2021 at 2:00 PM Chris Johns <chrisj at rtems.org> wrote:
>> On 12/2/21 7:27 am, Ryan Long wrote:
>>> Fixes CID #1468682 where target is dereferenced before it has been
>>> checked as to whether it is null or not in the
>>> rtems_debugger_target_swbreak_control function.
>>> cpukit/libdebugger/rtems-debugger-target.c | 5 +++--
>>> 1 file changed, 3 insertions(+), 2 deletions(-)
>>> diff --git a/cpukit/libdebugger/rtems-debugger-target.c b/cpukit/libdebugger/rtems-debugger-target.c
>>> index e495170..3726a6c 100644
>>> --- a/cpukit/libdebugger/rtems-debugger-target.c
>>> +++ b/cpukit/libdebugger/rtems-debugger-target.c
>>> @@ -171,17 +171,18 @@ int
>>> rtems_debugger_target_swbreak_control(bool insert, DB_UINT addr, DB_UINT kind)
>>> rtems_debugger_target* target = rtems_debugger->target;
>>> - rtems_debugger_target_swbreak* swbreaks = target->swbreaks.block;
>>> size_t swbreak_size;
>>> uint8_t* loc = (void*) addr;
>>> size_t i;
>>> int r;
>>> - if (target == NULL || swbreaks == NULL || kind != target->breakpoint_size) {
>>> + if (target == NULL || target->swbreaks.block == NULL ||
>>> + kind != target->breakpoint_size) {
>>> errno = EIO;
>>> return -1;
>>> + rtems_debugger_target_swbreak* swbreaks = target->swbreaks.block;
>> The debug server does not declare local vars in the body of functions. I would
>> prefer the this code base stays that way if that is OK?
> Good catch. This is a holdover from ANSI C that we should generally
> adhere to in RTEMS cpukit code for historical reasons.
Yes I agree. I understand and accept this is a personal thing and I stated my
preference in the other post.
I use this feature judicially in C++ where I think it is more important to do
so. In C++ a variable can be declared in a number of ways and places and I feel
being consistent aids readability. Compilers are smart enough to figure out when
a variable become active and we do not need to help.
