PowerPC Exception warnings
Fri Feb 12 20:21:48 UTC 2021
Hello,
The mvme2703 BSP is producing warnings for these lines of code:
https://git.rtems.org/rtems/tree/bsps/powerpc/shared/exceptions/ppc_exc.S#n132
https://git.rtems.org/rtems/tree/bsps/powerpc/shared/exceptions/ppc_exc.S#n135
The warnings is:
../../../bsps/powerpc/shared/exceptions/ppc_exc.S:132: Warning: invalid register
expression
../../../bsps/powerpc/shared/exceptions/ppc_exc.S:135: Warning: invalid register
expression
The code is:
	/* ppc405 has a critical exception using srr2/srr3 */
	WRAP	_FLVR=p405_crit _PRI=crit _SRR0=srr2 _SRR1=srr3 _RFI=rfci
	/* bookE has critical exception using csrr0 cssr1 */
	WRAP	_FLVR=bookE_crit _PRI=crit _SRR0=csrr0 _SRR1=csrr1 _RFI=rfci
I do not have enough PowerPC foo to fix this.
