[PATCH v2] Update motorola_power to irq-generic interrupt management
chrisj at rtems.org
chrisj at rtems.org
Sat Feb 13 01:38:49 UTC 2021
- Add support to the BSP to enable irq-generic management
- Update the powerpc shared irq code to support irq-generic. This
is an option in option for existing powerpc bsps. This change
should be simpler now
- Fix a number of issues in ISA IRQ controller handling by porting
fixes from the i386 (PC) BSP
Closes #4238
Closes #4239
bsps/powerpc/include/bsp/irq_supp.h | 5 +
.../motorola_powerpc/include/bsp/irq.h | 15 +-
.../powerpc/motorola_powerpc/start/bspstart.c | 7 +-
bsps/powerpc/shared/irq/i8259.c | 152 ++++++++++++++----
bsps/powerpc/shared/irq/irq_init.c | 15 +-
bsps/powerpc/shared/irq/openpic_i8259_irq.c | 27 ++--
bsps/powerpc/shared/irq/ppc-irq-generic.c | 117 ++++++++++++++
.../bsps/powerpc/motorola_powerpc/grp.yml | 2 +-
.../bsps/powerpc/motorola_powerpc/obj.yml | 3 +-
9 files changed, 286 insertions(+), 57 deletions(-)
create mode 100644 bsps/powerpc/shared/irq/ppc-irq-generic.c
diff --git a/bsps/powerpc/include/bsp/irq_supp.h b/bsps/powerpc/include/bsp/irq_supp.h
index 65af48c87f..fbb16d6211 100644
--- a/bsps/powerpc/include/bsp/irq_supp.h
+++ b/bsps/powerpc/include/bsp/irq_supp.h
@@ -50,6 +50,11 @@ extern int BSP_disable_irq_at_pic(const rtems_irq_number irqLine);
extern int BSP_setup_the_pic(rtems_irq_global_settings* config);
+ * Set up for the irq-generic.h interface.
+int BSP_rtems_irq_generic_set(rtems_irq_global_settings* config);
/* IRQ dispatcher to be defined by the PIC driver; note that it MUST
* implement shared interrupts.
* Note also that the exception frame passed to this handler is not very
diff --git a/bsps/powerpc/motorola_powerpc/include/bsp/irq.h b/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
index 3690dbbff7..cbb6ff69cf 100644
--- a/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
+++ b/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
@@ -19,9 +19,17 @@
#ifndef BSP_POWERPC_IRQ_H
#define BSP_POWERPC_IRQ_H
+#ifndef BSP_SHARED_HANDLER_SUPPORT
#define BSP_SHARED_HANDLER_SUPPORT 1
+#endif
#include <rtems/irq.h>
-#include <bsp/irq-default.h>
+ * Switch to using the generic support. Remove this when all BSPs have
+ * been converted.
+#define BSP_POWERPC_IRQ_GENERIC_SUPPORT 1
* 8259 edge/level control definitions at VIA
@@ -107,6 +115,8 @@ extern "C" {
#define BSP_IRQ_NUMBER (BSP_MISC_IRQ_MAX_OFFSET + 1)
#define BSP_LOWEST_OFFSET (BSP_ISA_IRQ_LOWEST_OFFSET)
#define BSP_MAX_OFFSET (BSP_MISC_IRQ_MAX_OFFSET)
+#define BSP_INTERRUPT_VECTOR_MIN (BSP_LOWEST_OFFSET)
+#define BSP_INTERRUPT_VECTOR_MAX (BSP_MAX_OFFSET)
* Some ISA IRQ symbolic name definition
@@ -191,6 +201,9 @@ int BSP_irq_ack_at_i8259s (const rtems_irq_number irqLine);
int BSP_irq_enabled_at_i8259s (const rtems_irq_number irqLine);
+unsigned short BSP_irq_suspend_i8259s(unsigned short mask);
+void BSP_irq_resume_i8259s(unsigned short in_progress_save);
extern void BSP_rtems_irq_mng_init(unsigned cpuId);
extern void BSP_i8259s_init(void);
diff --git a/bsps/powerpc/motorola_powerpc/start/bspstart.c b/bsps/powerpc/motorola_powerpc/start/bspstart.c
index e74b02c446..ef8418e2c6 100644
--- a/bsps/powerpc/motorola_powerpc/start/bspstart.c
+++ b/bsps/powerpc/motorola_powerpc/start/bspstart.c
@@ -27,6 +27,7 @@
#include <bsp/pci.h>
#include <bsp/openpic.h>
#include <bsp/irq.h>
+#include <bsp/irq-generic.h>
#include <libcpu/bat.h>
#include <libcpu/pte121.h>
#include <libcpu/cpuIdent.h>
@@ -334,10 +335,8 @@ static void bsp_early( void )
bsp_clicks_per_usec = BSP_bus_frequency/(BSP_time_base_divisor * 1000);
- * Initalize RTEMS IRQ system
- BSP_rtems_irq_mng_init(0);
+ /* Initialize interrupt support */
+ bsp_interrupt_initialize();
/* Activate the page table mappings only after
* initializing interrupts because the irq_mng_init()
diff --git a/bsps/powerpc/shared/irq/i8259.c b/bsps/powerpc/shared/irq/i8259.c
index 7363e87ba0..6a80e24946 100644
--- a/bsps/powerpc/shared/irq/i8259.c
+++ b/bsps/powerpc/shared/irq/i8259.c
@@ -12,6 +12,19 @@
#include <bsp.h>
+#define PIC_EOSI 0x60 ///< End of Specific Interrupt (EOSI)
+#define PIC_EOI 0x20 ///< Generic End of Interrupt (EOI)
+/* Operation control word type 3. Bit 3 (0x08) must be set. Even address. */
+#define PIC_OCW3_RIS 0x01 /* 1 = read IS, 0 = read IR */
+#define PIC_OCW3_RR 0x02 /* register read */
+#define PIC_OCW3_P 0x04 /* poll mode command */
+/* 0x08 must be 1 to select OCW3 vs OCW2 */
+#define PIC_OCW3_SEL 0x08 /* must be 1 */
+/* 0x10 must be 0 to select OCW3 vs ICW1 */
+#define PIC_OCW3_SMM 0x20 /* special mode mask */
+#define PIC_OCW3_ESMM 0x40 /* enable SMM */
| Cache for 1st and 2nd PIC IRQ line's status (enabled or disabled) register.
@@ -19,91 +32,137 @@
* lower byte is interrupt mask on the master PIC.
* while upper bits are interrupt on the slave PIC.
-volatile rtems_i8259_masks i8259s_cache = 0xfffb;
+static rtems_i8259_masks i8259s_imr_cache = 0xFFFB;
+static rtems_i8259_masks i8259s_in_progress = 0;
+static inline
+void BSP_i8259s_irq_update_master_imr( void )
+ rtems_i8259_masks mask = i8259s_in_progress | i8259s_imr_cache;
+ outport_byte( PIC_MASTER_IMR_IO_PORT, mask & 0xff );
+static inline
+void BSP_i8259s_irq_update_slave_imr( void )
+ outport_byte( PIC_SLAVE_IMR_IO_PORT, ( mask >> 8 ) & 0xff );
+ * Is the IRQ valid?
+static inline bool BSP_i8259s_irq_valid(const rtems_irq_number irqLine)
+ return ((int)irqLine >= BSP_ISA_IRQ_LOWEST_OFFSET) &&
+ ((int)irqLine <= BSP_ISA_IRQ_MAX_OFFSET);
+ * Read the IRR register. The default.
+static inline uint8_t BSP_i8259s_irq_int_request_reg(uint32_t ioport)
+ uint8_t isr;
+ inport_byte(ioport, isr);
+ return isr;
+ * Read the ISR register. Keep the default of the IRR.
+static inline uint8_t BSP_i8259s_irq_in_service_reg(uint32_t ioport)
+ uint8_t isr;
+ outport_byte(ioport, PIC_OCW3_SEL | PIC_OCW3_RR | PIC_OCW3_RIS);
+ outport_byte(ioport, PIC_OCW3_SEL | PIC_OCW3_RR);
+ return isr;
| Function: BSP_irq_disable_at_i8259s
| Description: Mask IRQ line in appropriate PIC chip.
-| Global Variables: i8259s_cache
+| Global Variables: i8259s_imr_cache, i8259s_in_progress
| Arguments: vector_offset - number of IRQ line to mask.
-| Returns: original state or -1 on error.
+| Returns: 0 is OK.
-int BSP_irq_disable_at_i8259s (const rtems_irq_number irqLine)
+int BSP_irq_disable_at_i8259s(const rtems_irq_number irqLine)
unsigned short mask;
rtems_interrupt_level level;
- int rval;
- if ( ((int)irqLine < BSP_ISA_IRQ_LOWEST_OFFSET) ||
- ((int)irqLine > BSP_ISA_IRQ_MAX_OFFSET)
+ if (!BSP_i8259s_irq_valid(irqLine))
return -1;
rtems_interrupt_disable(level);
mask = 1 << irqLine;
- rval = i8259s_cache & mask ? 0 : 1;
- i8259s_cache |= mask;
+ i8259s_imr_cache |= mask;
if (irqLine < 8)
- outport_byte(PIC_MASTER_IMR_IO_PORT, i8259s_cache & 0xff);
+ BSP_i8259s_irq_update_master_imr();
else
- outport_byte(PIC_SLAVE_IMR_IO_PORT, ((i8259s_cache & 0xff00) >> 8));
+ BSP_i8259s_irq_update_slave_imr();
rtems_interrupt_enable(level);
- return rval;
+ return 0;
| Function: BSP_irq_enable_at_i8259s
| Description: Unmask IRQ line in appropriate PIC chip.
| Arguments: irqLine - number of IRQ line to mask.
| Returns: Nothing.
-int BSP_irq_enable_at_i8259s (const rtems_irq_number irqLine)
+int BSP_irq_enable_at_i8259s(const rtems_irq_number irqLine)
- unsigned short mask;
+ unsigned short mask;
+ uint8_t isr;
+ uint8_t irr;
- ((int)irqLine > BSP_ISA_IRQ_MAX_OFFSET )
return 1;
- mask = ~(1 << irqLine);
- i8259s_cache &= mask;
+ mask = 1 << irqLine;
+ i8259s_imr_cache &= ~mask;
if (irqLine < 8)
+ isr = BSP_i8259s_irq_in_service_reg(PIC_MASTER_COMMAND_IO_PORT);
+ irr = BSP_i8259s_irq_int_request_reg(PIC_MASTER_COMMAND_IO_PORT);
else
+ isr = BSP_i8259s_irq_in_service_reg(PIC_SLAVE_COMMAND_IO_PORT);
+ irr = BSP_i8259s_irq_int_request_reg(PIC_SLAVE_COMMAND_IO_PORT);
return 0;
} /* mask_irq */
-int BSP_irq_enabled_at_i8259s (const rtems_irq_number irqLine)
+int BSP_irq_enabled_at_i8259s(const rtems_irq_number irqLine)
return 1;
mask = (1 << irqLine);
- return (~(i8259s_cache & mask));
+ return (~(i8259s_imr_cache & mask));
@@ -113,24 +172,47 @@ int BSP_irq_enabled_at_i8259s (const rtems_irq_number irqLine)
| Arguments: irqLine - number of IRQ line to acknowledge.
| Returns: Nothing.
-int BSP_irq_ack_at_i8259s (const rtems_irq_number irqLine)
+int BSP_irq_ack_at_i8259s(const rtems_irq_number irqLine)
+ uint8_t slave_isr = 0;
if (irqLine >= 8) {
- outport_byte(PIC_MASTER_COMMAND_IO_PORT, SLAVE_PIC_EOSI);
- outport_byte(PIC_SLAVE_COMMAND_IO_PORT, (PIC_EOSI | (irqLine - 8)));
- else {
- outport_byte(PIC_MASTER_COMMAND_IO_PORT, (PIC_EOSI | irqLine));
+ outport_byte(PIC_SLAVE_COMMAND_IO_PORT, PIC_EOI);
+ slave_isr = BSP_i8259s_irq_in_service_reg(PIC_SLAVE_COMMAND_IO_PORT);
+ * Only issue the EOI to the master if there are no more interrupts in
+ * service for the slave. i8259a data sheet page 18, The Special Fully Nested
+ * Mode, b.
+ if (slave_isr == 0)
+ outport_byte(PIC_MASTER_COMMAND_IO_PORT, PIC_EOI);
return 0;
} /* ackIRQ */
+ unsigned short in_progress_save = i8259s_in_progress;
+ i8259s_in_progress |= mask;
+ return in_progress_save;
+ i8259s_in_progress = in_progress_save;
- * init master 8259 interrupt controller
+ * Always mask at least current interrupt to prevent re-entrance
outport_byte(PIC_MASTER_COMMAND_IO_PORT, 0x11); /* Start init sequence */
outport_byte(PIC_MASTER_IMR_IO_PORT, 0x00);/* Vector base = 0 */
diff --git a/bsps/powerpc/shared/irq/irq_init.c b/bsps/powerpc/shared/irq/irq_init.c
index 1042c9d1a8..233c659b85 100644
--- a/bsps/powerpc/shared/irq/irq_init.c
+++ b/bsps/powerpc/shared/irq/irq_init.c
@@ -280,6 +280,7 @@ void BSP_rtems_irq_mng_init(unsigned cpuId)
int known_cpi_isa_bridge = 0;
#endif
int i;
+ int r;
* First initialize the Interrupt management hardware
@@ -351,7 +352,19 @@ void BSP_rtems_irq_mng_init(unsigned cpuId)
initial_config.irqBase = BSP_LOWEST_OFFSET;
initial_config.irqPrioTbl = irqPrioTable;
- if (!BSP_rtems_irq_mngt_set(&initial_config)) {
+#ifdef BSP_POWERPC_IRQ_GENERIC_SUPPORT
+#ifdef TRACE_IRQ_INIT
+ printk("RTEMS IRQ management: irq-generic\n");
+#endif
+ r = BSP_rtems_irq_generic_set(&initial_config);
+#else
+ printk("RTEMS IRQ management: legacy\n");
+#endif
+ r = BSP_rtems_irq_mngt_set(&initial_config);
+#endif
+ if (!r) {
* put something here that will show the failure...
diff --git a/bsps/powerpc/shared/irq/openpic_i8259_irq.c b/bsps/powerpc/shared/irq/openpic_i8259_irq.c
index 513b9ac3e0..2617555658 100644
--- a/bsps/powerpc/shared/irq/openpic_i8259_irq.c
+++ b/bsps/powerpc/shared/irq/openpic_i8259_irq.c
@@ -15,6 +15,7 @@
#include <bsp.h>
#include <bsp/irq_supp.h>
#ifndef BSP_HAS_NO_VME
#include <bsp/VMEConfig.h>
#endif
@@ -234,15 +235,15 @@ int C_dispatch_irq_handler (BSP_Exception_frame *frame, unsigned int excNum)
#if BSP_ISA_IRQ_NUMBER > 0
register unsigned isaIntr; /* boolean */
register unsigned oldMask = 0; /* old isa pic masks */
- register unsigned newMask; /* new isa pic masks */
#endif
if (excNum == ASM_DEC_VECTOR) {
- bsp_irq_dispatch_list(rtems_hdl_tbl, BSP_DECREMENTER, default_rtems_entry.hdl);
+ bsp_interrupt_handler_dispatch(BSP_DECREMENTER);
+#else
+ bsp_irq_dispatch_list(rtems_hdl_tbl, BSP_DECREMENTER, default_rtems_entry.hdl);
+#endif
return 0;
#if BSP_PCI_IRQ_NUMBER > 0
@@ -274,7 +275,7 @@ int C_dispatch_irq_handler (BSP_Exception_frame *frame, unsigned int excNum)
#ifdef BSP_PCI_ISA_BRIDGE_IRQ
-#if 0 == BSP_PCI_IRQ_NUMBER
+#if 0 == BSP_PCI_IRQ_NUMBER
#error "Configuration Error -- BSP w/o PCI IRQs MUST NOT define BSP_PCI_ISA_BRIDGE_IRQ"
#endif
isaIntr = (irq == BSP_PCI_ISA_BRIDGE_IRQ);
@@ -289,11 +290,7 @@ int C_dispatch_irq_handler (BSP_Exception_frame *frame, unsigned int excNum)
* store current PIC mask
- oldMask = i8259s_cache;
- newMask = oldMask | irq_mask_or_tbl [irq];
- i8259s_cache = newMask;
+ oldMask = BSP_irq_suspend_i8259s(irq_mask_or_tbl [irq]);
BSP_irq_ack_at_i8259s (irq);
if ( OpenPIC )
@@ -303,13 +300,15 @@ int C_dispatch_irq_handler (BSP_Exception_frame *frame, unsigned int excNum)
#endif
/* dispatch handlers */
+ bsp_interrupt_handler_dispatch(irq);
+#else
bsp_irq_dispatch_list(rtems_hdl_tbl, irq, default_rtems_entry.hdl);
+#endif
if (isaIntr) {
- i8259s_cache = oldMask;
+ BSP_irq_resume_i8259s(oldMask);
else
#endif
diff --git a/bsps/powerpc/shared/irq/ppc-irq-generic.c b/bsps/powerpc/shared/irq/ppc-irq-generic.c
new file mode 100644
index 0000000000..8a70109e52
--- /dev/null
+++ b/bsps/powerpc/shared/irq/ppc-irq-generic.c
@@ -0,0 +1,117 @@
+ * @file
+ * @ingroup RTEMSBSPsPowerPC
+ * @brief Generic Interrupt suppoer
+ * Copyright (C) 2021 Chris Johns. All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <stdlib.h>
+#include <rtems.h>
+#include <rtems/bspIo.h> /* for printk */
+#include <libcpu/spr.h>
+#include <bsp/irq_supp.h>
+#include <bsp/vectors.h>
+SPR_RW(BOOKE_TSR)
+SPR_RW(PPC405_TSR)
+/* legacy mode for bookE DEC exception;
+ * to avoid the double layer of function calls
+ * (dec_handler_bookE -> C_dispatch_irq_handler -> user handler)
+ * it is preferrable for the user to hook the DEC
+ * exception directly.
+ * However, the legacy mode works with less modifications
+ * of user code.
+static int C_dispatch_dec_handler_bookE (BSP_Exception_frame *frame, unsigned int excNum)
+ /* clear interrupt; we must do this
+ * before C_dispatch_irq_handler()
+ * re-enables MSR_EE.
+ * Note that PPC405 uses a different SPR# for TSR
+ if (ppc_cpu_is_bookE()==PPC_BOOKE_405)
+ _write_PPC405_TSR( BOOKE_TSR_DIS );
+ else
+ _write_BOOKE_TSR( BOOKE_TSR_DIS );
+ return C_dispatch_irq_handler(frame, ASM_DEC_VECTOR);
+ * RTEMS Global Interrupt Handler Management Routines
+ int r;
+ r = BSP_setup_the_pic(config);
+ if (!r)
+ return r;
+ ppc_exc_set_handler(ASM_EXT_VECTOR, C_dispatch_irq_handler);
+ if ( ppc_cpu_is_bookE() ) {
+ /* bookE decrementer interrupt needs to be cleared BEFORE
+ * dispatching the user ISR (because the user ISR is called
+ * with EE enabled)
+ * We do this so that existing DEC handlers can be used
+ * with minor modifications.
+ ppc_exc_set_handler(ASM_BOOKE_DEC_VECTOR, C_dispatch_dec_handler_bookE);
+ } else {
+ ppc_exc_set_handler(ASM_DEC_VECTOR, C_dispatch_irq_handler);
+ return 1;
+void bsp_interrupt_vector_enable(rtems_vector_number vector)
+ bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
+ BSP_enable_irq_at_pic(vector);
+void bsp_interrupt_vector_disable(rtems_vector_number vector)
+ BSP_disable_irq_at_pic(vector);
+rtems_status_code bsp_interrupt_facility_initialize(void)
+ * Initialize RTEMS IRQ system
+ BSP_rtems_irq_mng_init(0);
+ return RTEMS_SUCCESSFUL;
diff --git a/spec/build/bsps/powerpc/motorola_powerpc/grp.yml b/spec/build/bsps/powerpc/motorola_powerpc/grp.yml
index f256fec10f..a3ad2b115d 100644
--- a/spec/build/bsps/powerpc/motorola_powerpc/grp.yml
+++ b/spec/build/bsps/powerpc/motorola_powerpc/grp.yml
@@ -10,7 +10,7 @@ links:
- role: build-dependency
uid: ../../obj
- uid: ../../objirqdflt
+ uid: ../../objirq
uid: ../crti
diff --git a/spec/build/bsps/powerpc/motorola_powerpc/obj.yml b/spec/build/bsps/powerpc/motorola_powerpc/obj.yml
index 07ee6fa721..ae7b9f96e2 100644
--- a/spec/build/bsps/powerpc/motorola_powerpc/obj.yml
+++ b/spec/build/bsps/powerpc/motorola_powerpc/obj.yml
@@ -39,7 +39,7 @@ source:
- bsps/powerpc/shared/irq/irq_init.c
- bsps/powerpc/shared/irq/openpic.c
- bsps/powerpc/shared/irq/openpic_i8259_irq.c
-- bsps/powerpc/shared/irq/ppc-irq-legacy.c
+- bsps/powerpc/shared/irq/ppc-irq-generic.c
- bsps/powerpc/shared/mmu/bat.c
- bsps/powerpc/shared/mmu/mmuAsm.S
- bsps/powerpc/shared/mmu/pte121.c
@@ -57,5 +57,6 @@ source:
- bsps/powerpc/shared/start/zerobss.c
- bsps/shared/dev/getentropy/getentropy-cpucounter.c
- bsps/shared/dev/rtc/rtc-support.c
+- bsps/shared/irq/irq-default-handler.c
- bsps/shared/start/bspfatal-default.c
type: build
2.24.1
