[PATCH 0/3] bsps/zynq: Add cadence-SPI driver
Fri Feb 12 23:10:37 UTC 2021
On Fri, Feb 12, 2021 at 5:06 PM Chris Johns <chrisj at rtems.org> wrote:
> On 13/2/21 12:25 am, Jan Sommer wrote:
> > This patchset implements a driver for the cadence-spi
> > device of the Xilinx Zynq-7000 based SoCs  using the spidev API.s
> Thanks for the driver.
> A quick review of the differences between the Zynq and Ulttrascale in this
> document from Xilinx:
> https://www.xilinx.com/support/documentation/user_guides/ug1213-zynq-migration-guide.pdf
> shows the SPI hardware is the same. Should this driver be located under
> `bsps/shared/dev/spi` and then shared?
If Kinsey or Jan confirms, then yes it should. Kinsey has had a number
of drivers work after addressing 64-bit clean issues.
--joel
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210212/37b8671c/attachment.html>
