[PATCH 0/3] bsps/zynq: Add cadence-SPI driver
Fri Feb 12 23:14:13 UTC 2021
On 13/2/21 10:10 am, Joel Sherrill wrote:
> On Fri, Feb 12, 2021 at 5:06 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 13/2/21 12:25 am, Jan Sommer wrote:
>     > This patchset implements a driver for the cadence-spi
>     > device of the Xilinx Zynq-7000 based SoCs  using the spidev API.s
>     Thanks for the driver.
>     A quick review of the differences between the Zynq and Ulttrascale in this
>     document from Xilinx:
>     https://www.xilinx.com/support/documentation/user_guides/ug1213-zynq-migration-guide.pdf
>     <https://www.xilinx.com/support/documentation/user_guides/ug1213-zynq-migration-guide.pdf>
>     shows the SPI hardware is the same. Should this driver be located under
>     `bsps/shared/dev/spi` and then shared?
> If Kinsey or Jan confirms, then yes it should.
Thanks.
> Kinsey has had a number
> of drivers work after addressing 64-bit clean issues.
Nice. Are these in the tree?
