[PATCH 0/3] bsps/zynq: Add cadence-SPI driver
Chris Johns
chrisj at rtems.org
Fri Feb 12 23:21:10 UTC 2021
On 13/2/21 10:18 am, Kinsey Moore wrote:
> On 12/2/21 5:14 am, Chris Johns wrote:
>> On 13/2/21 10:10 am, Joel Sherrill wrote:
>>> On Fri, Feb 12, 2021 at 5:06 PM Chris Johns <chrisj at rtems.org
>>> <mailto:chrisj at rtems.org>> wrote:
>>> On 13/2/21 12:25 am, Jan Sommer wrote:
>>> > This patchset implements a driver for the cadence-spi
>>> > device of the Xilinx Zynq-7000 based SoCs using the spidev API.s
>>> Thanks for the driver.
>>> A quick review of the differences between the Zynq and Ulttrascale in this
>>> document from Xilinx:
>>> https://www.xilinx.com/support/documentation/user_guides/ug1213-zynq-migration-guide.pdf
>>> <https://www.xilinx.com/support/documentation/user_guides/ug1213-zynq-migration-guide.pdf>
>>> shows the SPI hardware is the same. Should this driver be located under
>>> `bsps/shared/dev/spi` and then shared?
>>> If Kinsey or Jan confirms, then yes it should.
>> Thanks.
>>> Kinsey has had a number
>>> of drivers work after addressing 64-bit clean issues.
>> Nice. Are these in the tree?
> Looking at the register setup for the two SPI instances in MPSoC, I have verified that these peripherals are identical. It should definitely go in bsps/shared/dev/spi.
Thanks.
> I have already committed some of the driver movement from Zynq or ARM to bsps/shared/dev. There is still quite a bit more to pull out of the Zynq BSP that I haven't quite gotten to.
Awesome and thanks. It is great to see this happening.
