[PATCH 0/3] bsps/zynq: Add cadence-SPI driver
Kinsey Moore
kinsey.moore at oarcorp.com
Fri Feb 12 23:18:19 UTC 2021
On 12/2/21 5:14 am, Chris Johns wrote:
>On 13/2/21 10:10 am, Joel Sherrill wrote:
>> On Fri, Feb 12, 2021 at 5:06 PM Chris Johns <chrisj at rtems.org
>> <mailto:chrisj at rtems.org>> wrote:
>> On 13/2/21 12:25 am, Jan Sommer wrote:
>> > This patchset implements a driver for the cadence-spi
>> > device of the Xilinx Zynq-7000 based SoCs using the spidev API.s
>> Thanks for the driver.
>> A quick review of the differences between the Zynq and Ulttrascale in this
>> document from Xilinx:
>> https://www.xilinx.com/support/documentation/user_guides/ug1213-zynq-migration-guide.pdf
>> <https://www.xilinx.com/support/documentation/user_guides/ug1213-zynq-migration-guide.pdf>
>> shows the SPI hardware is the same. Should this driver be located under
>> `bsps/shared/dev/spi` and then shared?
>> If Kinsey or Jan confirms, then yes it should.
> Thanks.
>> Kinsey has had a number
>> of drivers work after addressing 64-bit clean issues.
> Nice. Are these in the tree?
Looking at the register setup for the two SPI instances in MPSoC, I have verified that these peripherals are identical. It should definitely go in bsps/shared/dev/spi.
I have already committed some of the driver movement from Zynq or ARM to bsps/shared/dev. There is still quite a bit more to pull out of the Zynq BSP that I haven't quite gotten to.
Kinsey
