[PATCH v2] Update motorola_power to irq-generic interrupt management
Sat Feb 13 01:58:38 UTC 2021
On Fri, Feb 12, 2021 at 7:38 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Add support to the BSP to enable irq-generic management
> - Update the powerpc shared irq code to support irq-generic. This
>   is an option in option for existing powerpc bsps. This change
Probably just an option. :)
I'm cool with the patch. This code is all over the place formatting
wise and caution is advised.
>   should be simpler now
> - Fix a number of issues in ISA IRQ controller handling by porting
>   fixes from the i386 (PC) BSP
> Closes #4238
> Closes #4239
>  bsps/powerpc/include/bsp/irq_supp.h           |   5 +
>  .../motorola_powerpc/include/bsp/irq.h        |  15 +-
>  .../powerpc/motorola_powerpc/start/bspstart.c |   7 +-
>  bsps/powerpc/shared/irq/i8259.c               | 152 ++++++++++++++----
>  bsps/powerpc/shared/irq/irq_init.c            |  15 +-
>  bsps/powerpc/shared/irq/openpic_i8259_irq.c   |  27 ++--
>  bsps/powerpc/shared/irq/ppc-irq-generic.c     | 117 ++++++++++++++
>  .../bsps/powerpc/motorola_powerpc/grp.yml     |   2 +-
>  .../bsps/powerpc/motorola_powerpc/obj.yml     |   3 +-
>  9 files changed, 286 insertions(+), 57 deletions(-)
>  create mode 100644 bsps/powerpc/shared/irq/ppc-irq-generic.c
> diff --git a/bsps/powerpc/include/bsp/irq_supp.h
> b/bsps/powerpc/include/bsp/irq_supp.h
> index 65af48c87f..fbb16d6211 100644
> --- a/bsps/powerpc/include/bsp/irq_supp.h
> +++ b/bsps/powerpc/include/bsp/irq_supp.h
> @@ -50,6 +50,11 @@ extern int  BSP_disable_irq_at_pic(const
> rtems_irq_number irqLine);
>  extern int  BSP_setup_the_pic(rtems_irq_global_settings* config);
> + * Set up for the irq-generic.h interface.
> +int BSP_rtems_irq_generic_set(rtems_irq_global_settings* config);
>  /* IRQ dispatcher to be defined by the PIC driver; note that it MUST
>   * implement shared interrupts.
>   * Note also that the exception frame passed to this handler is not very
> diff --git a/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
> b/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
> index 3690dbbff7..cbb6ff69cf 100644
> --- a/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
> +++ b/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
> @@ -19,9 +19,17 @@
>  #ifndef BSP_POWERPC_IRQ_H
>  #define BSP_POWERPC_IRQ_H
> +#ifndef BSP_SHARED_HANDLER_SUPPORT
>  #define BSP_SHARED_HANDLER_SUPPORT      1
> +#endif
>  #include <rtems/irq.h>
> -#include <bsp/irq-default.h>
> + * Switch to using the generic support. Remove this when all BSPs have
> + * been converted.
> +#define BSP_POWERPC_IRQ_GENERIC_SUPPORT 1
>   * 8259 edge/level control definitions at VIA
> @@ -107,6 +115,8 @@ extern "C" {
>  #define BSP_IRQ_NUMBER                 (BSP_MISC_IRQ_MAX_OFFSET + 1)
>  #define BSP_LOWEST_OFFSET              (BSP_ISA_IRQ_LOWEST_OFFSET)
>  #define BSP_MAX_OFFSET                 (BSP_MISC_IRQ_MAX_OFFSET)
> +#define BSP_INTERRUPT_VECTOR_MIN       (BSP_LOWEST_OFFSET)
> +#define BSP_INTERRUPT_VECTOR_MAX       (BSP_MAX_OFFSET)
>   * Some ISA IRQ symbolic name definition
> @@ -191,6 +201,9 @@ int BSP_irq_ack_at_i8259s                   (const
>  int BSP_irq_enabled_at_i8259s          (const rtems_irq_number irqLine);
> +unsigned short BSP_irq_suspend_i8259s(unsigned short mask);
> +void BSP_irq_resume_i8259s(unsigned short in_progress_save);
>  extern void BSP_rtems_irq_mng_init(unsigned cpuId);
>  extern void BSP_i8259s_init(void);
> diff --git a/bsps/powerpc/motorola_powerpc/start/bspstart.c
> b/bsps/powerpc/motorola_powerpc/start/bspstart.c
> index e74b02c446..ef8418e2c6 100644
> --- a/bsps/powerpc/motorola_powerpc/start/bspstart.c
> +++ b/bsps/powerpc/motorola_powerpc/start/bspstart.c
> @@ -27,6 +27,7 @@
>  #include <bsp/pci.h>
>  #include <bsp/openpic.h>
>  #include <bsp/irq.h>
> +#include <bsp/irq-generic.h>
>  #include <libcpu/bat.h>
>  #include <libcpu/pte121.h>
>  #include <libcpu/cpuIdent.h>
> @@ -334,10 +335,8 @@ static void bsp_early( void )
>    bsp_clicks_per_usec   = BSP_bus_frequency/(BSP_time_base_divisor *
> 1000);
> -   * Initalize RTEMS IRQ system
> -  BSP_rtems_irq_mng_init(0);
> +  /* Initialize interrupt support */
> +  bsp_interrupt_initialize();
>    /* Activate the page table mappings only after
>     * initializing interrupts because the irq_mng_init()
> diff --git a/bsps/powerpc/shared/irq/i8259.c
> b/bsps/powerpc/shared/irq/i8259.c
> index 7363e87ba0..6a80e24946 100644
> --- a/bsps/powerpc/shared/irq/i8259.c
> +++ b/bsps/powerpc/shared/irq/i8259.c
> @@ -12,6 +12,19 @@
>  #include <bsp.h>
> +#define PIC_EOSI        0x60    ///< End of Specific Interrupt (EOSI)
> +#define PIC_EOI         0x20    ///< Generic End of Interrupt (EOI)
> +/* Operation control word type 3.  Bit 3 (0x08) must be set. Even
> address. */
> +#define PIC_OCW3_RIS        0x01            /* 1 = read IS, 0 = read IR */
> +#define PIC_OCW3_RR         0x02            /* register read */
> +#define PIC_OCW3_P          0x04            /* poll mode command */
> +/* 0x08 must be 1 to select OCW3 vs OCW2 */
> +#define PIC_OCW3_SEL        0x08            /* must be 1 */
> +/* 0x10 must be 0 to select OCW3 vs ICW1 */
> +#define PIC_OCW3_SMM        0x20            /* special mode mask */
> +#define PIC_OCW3_ESMM       0x40            /* enable SMM */
>  | Cache for 1st and 2nd PIC IRQ line's status (enabled or disabled)
> register.
> @@ -19,91 +32,137 @@
>   * lower byte is interrupt mask on the master PIC.
>   * while upper bits are interrupt on the slave PIC.
> -volatile rtems_i8259_masks i8259s_cache = 0xfffb;
> +static rtems_i8259_masks i8259s_imr_cache = 0xFFFB;
> +static rtems_i8259_masks i8259s_in_progress = 0;
> +static inline
> +void BSP_i8259s_irq_update_master_imr( void )
> +  rtems_i8259_masks mask = i8259s_in_progress | i8259s_imr_cache;
> +  outport_byte( PIC_MASTER_IMR_IO_PORT, mask & 0xff );
> +static inline
> +void BSP_i8259s_irq_update_slave_imr( void )
> +  outport_byte( PIC_SLAVE_IMR_IO_PORT, ( mask >> 8 ) & 0xff );
> + * Is the IRQ valid?
> +static inline bool BSP_i8259s_irq_valid(const rtems_irq_number irqLine)
> +  return ((int)irqLine >= BSP_ISA_IRQ_LOWEST_OFFSET) &&
> +    ((int)irqLine <= BSP_ISA_IRQ_MAX_OFFSET);
> + * Read the IRR register. The default.
> +static inline uint8_t BSP_i8259s_irq_int_request_reg(uint32_t ioport)
> +  uint8_t isr;
> +  inport_byte(ioport, isr);
> +  return isr;
> + * Read the ISR register. Keep the default of the IRR.
> +static inline uint8_t BSP_i8259s_irq_in_service_reg(uint32_t ioport)
> +  uint8_t isr;
> +  outport_byte(ioport, PIC_OCW3_SEL | PIC_OCW3_RR | PIC_OCW3_RIS);
> +  outport_byte(ioport, PIC_OCW3_SEL | PIC_OCW3_RR);
> +  return isr;
>  |         Function:  BSP_irq_disable_at_i8259s
>  |      Description: Mask IRQ line in appropriate PIC chip.
> -| Global Variables: i8259s_cache
> +| Global Variables: i8259s_imr_cache, i8259s_in_progress
>  |        Arguments: vector_offset - number of IRQ line to mask.
> -|          Returns: original state or -1 on error.
> +|          Returns: 0 is OK.
> -int BSP_irq_disable_at_i8259s    (const rtems_irq_number irqLine)
> +int BSP_irq_disable_at_i8259s(const rtems_irq_number irqLine)
>    unsigned short        mask;
>    rtems_interrupt_level level;
> -  int                   rval;
> -  if ( ((int)irqLine < BSP_ISA_IRQ_LOWEST_OFFSET) ||
> -       ((int)irqLine > BSP_ISA_IRQ_MAX_OFFSET)
> +  if (!BSP_i8259s_irq_valid(irqLine))
>      return -1;
>    rtems_interrupt_disable(level);
>    mask = 1 << irqLine;
> -  rval = i8259s_cache & mask ? 0 : 1;
> -  i8259s_cache |= mask;
> +  i8259s_imr_cache |= mask;
>    if (irqLine < 8)
> -    outport_byte(PIC_MASTER_IMR_IO_PORT, i8259s_cache & 0xff);
> +    BSP_i8259s_irq_update_master_imr();
>    else
> -    outport_byte(PIC_SLAVE_IMR_IO_PORT, ((i8259s_cache & 0xff00) >> 8));
> +    BSP_i8259s_irq_update_slave_imr();
>    rtems_interrupt_enable(level);
> -  return rval;
> +  return 0;
>  |         Function:  BSP_irq_enable_at_i8259s
>  |      Description: Unmask IRQ line in appropriate PIC chip.
>  |        Arguments: irqLine - number of IRQ line to mask.
>  |          Returns: Nothing.
> -int BSP_irq_enable_at_i8259s    (const rtems_irq_number irqLine)
> +int BSP_irq_enable_at_i8259s(const rtems_irq_number irqLine)
> -  unsigned short        mask;
> +  unsigned short        mask;
> +  uint8_t               isr;
> +  uint8_t               irr;
> -       ((int)irqLine > BSP_ISA_IRQ_MAX_OFFSET )
>      return 1;
> -  mask = ~(1 << irqLine);
> -  i8259s_cache &= mask;
> +  mask = 1 << irqLine;
> +  i8259s_imr_cache &= ~mask;
>    if (irqLine < 8)
> +    isr = BSP_i8259s_irq_in_service_reg(PIC_MASTER_COMMAND_IO_PORT);
> +    irr = BSP_i8259s_irq_int_request_reg(PIC_MASTER_COMMAND_IO_PORT);
>    else
> +    isr = BSP_i8259s_irq_in_service_reg(PIC_SLAVE_COMMAND_IO_PORT);
> +    irr = BSP_i8259s_irq_int_request_reg(PIC_SLAVE_COMMAND_IO_PORT);
>    return 0;
>  } /* mask_irq */
> -int BSP_irq_enabled_at_i8259s          (const rtems_irq_number irqLine)
> +int BSP_irq_enabled_at_i8259s(const rtems_irq_number irqLine)
>      return 1;
>    mask = (1 << irqLine);
> -  return  (~(i8259s_cache & mask));
> +  return  (~(i8259s_imr_cache & mask));
> @@ -113,24 +172,47 @@ int BSP_irq_enabled_at_i8259s             (const
>  |        Arguments: irqLine - number of IRQ line to acknowledge.
>  |          Returns: Nothing.
> -int BSP_irq_ack_at_i8259s      (const rtems_irq_number irqLine)
> +int BSP_irq_ack_at_i8259s(const rtems_irq_number irqLine)
> +  uint8_t slave_isr = 0;
>    if (irqLine >= 8) {
> -    outport_byte(PIC_MASTER_COMMAND_IO_PORT, SLAVE_PIC_EOSI);
> -    outport_byte(PIC_SLAVE_COMMAND_IO_PORT, (PIC_EOSI | (irqLine - 8)));
> -  else {
> -    outport_byte(PIC_MASTER_COMMAND_IO_PORT, (PIC_EOSI | irqLine));
> +   outport_byte(PIC_SLAVE_COMMAND_IO_PORT, PIC_EOI);
> +   slave_isr = BSP_i8259s_irq_in_service_reg(PIC_SLAVE_COMMAND_IO_PORT);
> +   * Only issue the EOI to the master if there are no more interrupts in
> +   * service for the slave. i8259a data sheet page 18, The Special Fully
> Nested
> +   * Mode, b.
> +  if (slave_isr == 0)
> +    outport_byte(PIC_MASTER_COMMAND_IO_PORT, PIC_EOI);
>    return 0;
>  } /* ackIRQ */
> +  unsigned short in_progress_save = i8259s_in_progress;
> +  i8259s_in_progress |= mask;
> +  return in_progress_save;
> +  i8259s_in_progress = in_progress_save;
> -   * init master 8259 interrupt controller
> +   * Always mask at least current interrupt to prevent re-entrance
>    outport_byte(PIC_MASTER_COMMAND_IO_PORT, 0x11); /* Start init sequence
>    outport_byte(PIC_MASTER_IMR_IO_PORT, 0x00);/* Vector base  = 0 */
> diff --git a/bsps/powerpc/shared/irq/irq_init.c
> b/bsps/powerpc/shared/irq/irq_init.c
> index 1042c9d1a8..233c659b85 100644
> --- a/bsps/powerpc/shared/irq/irq_init.c
> +++ b/bsps/powerpc/shared/irq/irq_init.c
> @@ -280,6 +280,7 @@ void BSP_rtems_irq_mng_init(unsigned cpuId)
>    int known_cpi_isa_bridge = 0;
>  #endif
>    int i;
> +  int r;
>     * First initialize the Interrupt management hardware
> @@ -351,7 +352,19 @@ void BSP_rtems_irq_mng_init(unsigned cpuId)
>      initial_config.irqBase     = BSP_LOWEST_OFFSET;
>      initial_config.irqPrioTbl  = irqPrioTable;
> -    if (!BSP_rtems_irq_mngt_set(&initial_config)) {
> +#ifdef BSP_POWERPC_IRQ_GENERIC_SUPPORT
> +#ifdef TRACE_IRQ_INIT
> +    printk("RTEMS IRQ management: irq-generic\n");
> +#endif
> +    r = BSP_rtems_irq_generic_set(&initial_config);
> +#else
> +    printk("RTEMS IRQ management: legacy\n");
> +#endif
> +    r = BSP_rtems_irq_mngt_set(&initial_config);
> +#endif
> +    if (!r) {
>         * put something here that will show the failure...
> diff --git a/bsps/powerpc/shared/irq/openpic_i8259_irq.c
> b/bsps/powerpc/shared/irq/openpic_i8259_irq.c
> index 513b9ac3e0..2617555658 100644
> --- a/bsps/powerpc/shared/irq/openpic_i8259_irq.c
> +++ b/bsps/powerpc/shared/irq/openpic_i8259_irq.c
> @@ -15,6 +15,7 @@
>  #include <bsp.h>
>  #include <bsp/irq_supp.h>
>  #ifndef BSP_HAS_NO_VME
>  #include <bsp/VMEConfig.h>
>  #endif
> @@ -234,15 +235,15 @@ int C_dispatch_irq_handler (BSP_Exception_frame
> *frame, unsigned int excNum)
>  #if BSP_ISA_IRQ_NUMBER > 0
>    register unsigned isaIntr;                  /* boolean */
>    register unsigned oldMask = 0;             /* old isa pic masks */
> -  register unsigned newMask;                  /* new isa pic masks */
>  #endif
>    if (excNum == ASM_DEC_VECTOR) {
> -       bsp_irq_dispatch_list(rtems_hdl_tbl, BSP_DECREMENTER,
> default_rtems_entry.hdl);
> +    bsp_interrupt_handler_dispatch(BSP_DECREMENTER);
> +#else
> +    bsp_irq_dispatch_list(rtems_hdl_tbl, BSP_DECREMENTER,
> +#endif
>      return 0;
>  #if BSP_PCI_IRQ_NUMBER > 0
> @@ -274,7 +275,7 @@ int C_dispatch_irq_handler (BSP_Exception_frame
>  #ifdef BSP_PCI_ISA_BRIDGE_IRQ
> -#if 0 == BSP_PCI_IRQ_NUMBER
> +#if 0 == BSP_PCI_IRQ_NUMBER
>  #error "Configuration Error -- BSP w/o PCI IRQs MUST NOT define
> BSP_PCI_ISA_BRIDGE_IRQ"
>  #endif
>    isaIntr = (irq == BSP_PCI_ISA_BRIDGE_IRQ);
> @@ -289,11 +290,7 @@ int C_dispatch_irq_handler (BSP_Exception_frame
>       * store current PIC mask
> -    oldMask = i8259s_cache;
> -    newMask = oldMask | irq_mask_or_tbl [irq];
> -    i8259s_cache = newMask;
> +    oldMask = BSP_irq_suspend_i8259s(irq_mask_or_tbl [irq]);
>      BSP_irq_ack_at_i8259s (irq);
>         if ( OpenPIC )
> @@ -303,13 +300,15 @@ int C_dispatch_irq_handler (BSP_Exception_frame
>  #endif
>    /* dispatch handlers */
> +  bsp_interrupt_handler_dispatch(irq);
> +#else
>    bsp_irq_dispatch_list(rtems_hdl_tbl, irq, default_rtems_entry.hdl);
> +#endif
>    if (isaIntr)  {
> -    i8259s_cache = oldMask;
> +    BSP_irq_resume_i8259s(oldMask);
>    else
>  #endif
> diff --git a/bsps/powerpc/shared/irq/ppc-irq-generic.c
> b/bsps/powerpc/shared/irq/ppc-irq-generic.c
> new file mode 100644
> index 0000000000..8a70109e52
> --- /dev/null
> +++ b/bsps/powerpc/shared/irq/ppc-irq-generic.c
> @@ -0,0 +1,117 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup RTEMSBSPsPowerPC
> + * @brief Generic Interrupt suppoer
> + * Copyright (C) 2021 Chris Johns. All rights reserved.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#include <stdlib.h>
> +#include <rtems.h>
> +#include <rtems/bspIo.h> /* for printk */
> +#include <libcpu/spr.h>
> +#include <bsp/irq_supp.h>
> +#include <bsp/vectors.h>
> +SPR_RW(BOOKE_TSR)
> +SPR_RW(PPC405_TSR)
> +/* legacy mode for bookE DEC exception;
> + * to avoid the double layer of function calls
> + * (dec_handler_bookE -> C_dispatch_irq_handler -> user handler)
> + * it is preferrable for the user to hook the DEC
> + * exception directly.
> + * However, the legacy mode works with less modifications
> + * of user code.
> +static int C_dispatch_dec_handler_bookE (BSP_Exception_frame *frame,
> +  /* clear interrupt; we must do this
> +   * before C_dispatch_irq_handler()
> +   * re-enables MSR_EE.
> +   * Note that PPC405 uses a different SPR# for TSR
> +  if (ppc_cpu_is_bookE()==PPC_BOOKE_405)
> +    _write_PPC405_TSR( BOOKE_TSR_DIS );
> +  else
> +    _write_BOOKE_TSR( BOOKE_TSR_DIS );
> +  return C_dispatch_irq_handler(frame, ASM_DEC_VECTOR);
> + * RTEMS Global Interrupt Handler Management Routines
> +  int r;
> +  r = BSP_setup_the_pic(config);
> +  if (!r)
> +    return r;
> +  ppc_exc_set_handler(ASM_EXT_VECTOR, C_dispatch_irq_handler);
> +  if ( ppc_cpu_is_bookE() ) {
> +    /* bookE decrementer interrupt needs to be cleared BEFORE
> +     * dispatching the user ISR (because the user ISR is called
> +     * with EE enabled)
> +     * We do this so that existing DEC handlers can be used
> +     * with minor modifications.
> +    ppc_exc_set_handler(ASM_BOOKE_DEC_VECTOR,
> C_dispatch_dec_handler_bookE);
> +  } else {
> +    ppc_exc_set_handler(ASM_DEC_VECTOR, C_dispatch_irq_handler);
> +  return 1;
> +void bsp_interrupt_vector_enable(rtems_vector_number vector)
> +  bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
> +  BSP_enable_irq_at_pic(vector);
> +void bsp_interrupt_vector_disable(rtems_vector_number vector)
> +  BSP_disable_irq_at_pic(vector);
> +rtems_status_code bsp_interrupt_facility_initialize(void)
> +   * Initialize RTEMS IRQ system
> +  BSP_rtems_irq_mng_init(0);
> +  return RTEMS_SUCCESSFUL;
> diff --git a/spec/build/bsps/powerpc/motorola_powerpc/grp.yml
> b/spec/build/bsps/powerpc/motorola_powerpc/grp.yml
> index f256fec10f..a3ad2b115d 100644
> --- a/spec/build/bsps/powerpc/motorola_powerpc/grp.yml
> +++ b/spec/build/bsps/powerpc/motorola_powerpc/grp.yml
> @@ -10,7 +10,7 @@ links:
>  - role: build-dependency
>    uid: ../../obj
> -  uid: ../../objirqdflt
> +  uid: ../../objirq
>    uid: ../crti
> diff --git a/spec/build/bsps/powerpc/motorola_powerpc/obj.yml
> b/spec/build/bsps/powerpc/motorola_powerpc/obj.yml
> index 07ee6fa721..ae7b9f96e2 100644
> --- a/spec/build/bsps/powerpc/motorola_powerpc/obj.yml
> +++ b/spec/build/bsps/powerpc/motorola_powerpc/obj.yml
> @@ -39,7 +39,7 @@ source:
>  - bsps/powerpc/shared/irq/irq_init.c
>  - bsps/powerpc/shared/irq/openpic.c
>  - bsps/powerpc/shared/irq/openpic_i8259_irq.c
> -- bsps/powerpc/shared/irq/ppc-irq-legacy.c
> +- bsps/powerpc/shared/irq/ppc-irq-generic.c
>  - bsps/powerpc/shared/mmu/bat.c
>  - bsps/powerpc/shared/mmu/mmuAsm.S
>  - bsps/powerpc/shared/mmu/pte121.c
> @@ -57,5 +57,6 @@ source:
>  - bsps/powerpc/shared/start/zerobss.c
>  - bsps/shared/dev/getentropy/getentropy-cpucounter.c
>  - bsps/shared/dev/rtc/rtc-support.c
> +- bsps/shared/irq/irq-default-handler.c
>  - bsps/shared/start/bspfatal-default.c
>  type: build
> 2.24.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210212/708b4c82/attachment-0001.html>
