sifive risc-v hifive unleashed bsp (qemu)
    Sanskar Khandelwal
    kdsanskar07 at gmail.com
    Sun Feb 14 03:40:21 UTC 2021
Thanks everyone for your help these are some very helpful replies to start.
--sanskar
On Sat, Feb 13, 2021 at 9:30 PM Joel Sherrill <joel at rtems.org> wrote:
> On Sat, Feb 13, 2021, 4:16 AM Hesham Almatary <
> hesham.almatary at cl.cam.ac.uk> wrote:
>> On Sat, 13 Feb 2021 at 10:59, Eshan Dhawan <eshandhawan51 at gmail.com>
>> wrote:
>> > On 13-Feb-2021, at 1:53 PM, Sanskar Khandelwal <kdsanskar07 at gmail.com>
>> wrote:
>> > On Sat, Feb 13, 2021 at 9:30 AM Joel Sherrill <joel at rtems.org> wrote:
>> >> On Fri, Feb 12, 2021, 8:47 PM Rohan kumar <krohan8870 at gmail.co> wrote:
>> >>> I will look into this in more detail and get back to you but in mean
>> time I want to contribute to any issues so can you suggest any thats need
>> to be solved or how do I look for from my own.
>> >> Projects or just smaller issues?
>> > Actually I am looking for some small issues related to this project so
>> I can get some experience.
>> > before the project, I think this help me write better proposal and
>> understand codebase more easily and faster.
>> > Also can you tell me status of the below tickets and are they open for
>> participation? Actually I haven't decided project right now i am just
>> learning about them so I can make better decision like which project suits
>> me better according to may skills and experience level.
>> > But I am looking for project related to risc-v, I found this very
>> interesting that's why I am asking for any issue related to this.
>> >  #3337 : RISC-V Port in Supervisor Mode
>> >  #4182 : Port Rust to RTEMS
>> > Also can share some reference links so i can start, I have build the
>> riscv/rv64imac on my laptop but i dont know how do i simulate it on qemu.
>> > Hello sanskar
>> > I use this to run test suites
>> > Although I am not quite sure if you were wanting this or something else
>> > qemu-system-riscv32 -no-reboot -nographic -machine virt -m 256M -kernel
>> hello.exe
>> For RV64 and recent QEMU versions, the command would be:
>> qemu-system-riscv64 -no-reboot -nographic -machine virt -m 256M -bios
>> hello.exe
> To work on the BSP, you definitely have to have the RISC-V toolchain and
> being ae to run tests from existing RISC-V BSPs and used gdb with that is a
> foundation you have to have.
> Beyond that, there are a few prep things needed for any BSP.
> + You need to find documentation on the board and its peripherals. This
> should be sufficiently detailed so you know the memory map and what each
> peripheral's model/name is
> + Find candidate drivers for the peripherals in RTEMS that are already
> working on other BSPs.
> + Look at the build structure for a BSP. You will likely reuse a fair
> amount of shared code for startup, clock, and console.
> + If you can't find any code to reuse, BSDs and vendor kits are often
> useful. Beware of incompatible licensing and ask for help to ensure you are
> potentially starting from something we will accept and is right technically.
> + Linker script needs to use shared infrastructure and map this board into
> that.
> + You can put together a minimal bsp that has a polled console and uses
> the idle thread ticker as a first major milestone. Then incrementally add
> clock tick, etc.
> If SiFive has a bare metal setup (no OS) for this board, I find it useful
> to make sure I can get that type of thing working.
> Basically ensure you have something working to compare against and find
> code to share as much as possible. Homework can make things a lot easier.
> --joel
>> > - - Eshan
>> > thanks
>> > sanskar
>> >> There is a tag in the ticketing system for small projects but this
>> query makes me wonder if some should be closed. Deciding a ticket is dead
>> is good. :)
>> https://devel.rtems.org/query?status=accepted&status=assigned&status=new&status=reopened&keywords=~Small&col=id&col=summary&col=status&col=owner&col=type&col=priority&col=milestone&order=priority
>> >> Looking at Coverity is a quick way to find a small task. Some tickets
>> geared to adding a test aren't bad.
>> >> --joel
>> >>> Thanks
>> >>> Sanskar
>> >>> On Fri, Feb 12, 2021, 3:01 PM Hesham Almatary <
>> >>>> On Fri, 12 Feb 2021 at 11:24, Sanskar Khandelwal <
>> kdsanskar07 at gmail.com> wrote:
>> >>>> > Hello joel,
>> >>>> > 1. #4162 : sifive risc-v hifive unleashed bsp (qemu)
>> >>>> > As you mentioned this a good project i thought to search more
>> about this project I learned a lot while doing so but I still don't
>> understand what is the goal of this project (the description on the ticket
>> is not very detailed ) also I don't have any idea on how to make approach
>> for this project right now so if you can clear both my doubt it will be big
>> help.
>> >>>> You'd need to identify the devices for this platform that QEMU
>> >>>> supports (e.g., networking, UART, flash, etc?) and propose some
>> >>>> timeline to implement (a subset of) them. That would be part of your
>> >>>> proposal evaluation.
>> >>>> > Also as you mention that this can be a big task for a gsoc time
>> frame I am thinking that I can do some of it after gsoc too.
>> >>>> > Also I looked for some more open projects and found these
>> interesting so I wanted to know if these are open for participation for
>> gsoc and what's their status and what further enhancement you are looking
>> at each of them.
>> >>>> > 2. #3337 : RISC-V Port in Supervisor Mode
>> >>>> > 3. #4182 : Port Rust to RTEMS
>> >>>> > Another thing is that while I am learning more about these
>> projects I want to contribute, so if you can tell me about any issue that I
>> can work on, it will be nice. I think this will help get me more familiar
>> with rtems too.
>> >>>> > Thanks
>> >>>> > Sanskar
>> >>>> > _______________________________________________
>> >>>> > devel mailing list
>> >>>> > devel at rtems.org
>> >>>> > http://lists.rtems.org/mailman/listinfo/devel
>> >>>> devel mailing list
>> >>>> devel at rtems.org
>> >>> devel mailing list
>> >>> devel at rtems.org
>> >> devel mailing list
>> >> devel at rtems.org
>> > devel mailing list
>> > devel at rtems.org
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210214/c99d3e6d/attachment-0001.html>
