[PATCH] tests/validation: Fix 64bit test failure
Kinsey Moore
kinsey.moore at oarcorp.com
Mon Feb 15 16:36:32 UTC 2021
I’m not sure this patch reasonably backports to 5. There have been some changes in the organization of the message code and the modifications here are relevant to the message queue config structure that was added. The function signatures could be updated, but the remainder does not apply.
Kinsey
Sent: Monday, February 15, 2021 10:16
To: Kinsey Moore <kinsey.moore at oarcorp.com>
Cc: rtems-devel at rtems.org <devel at rtems.org>; ryan long <rlong at localhost.localdomain>
Subject: Re: [PATCH] tests/validation: Fix 64bit test failure
Should this have a ticket and be applied to 5 also? There are other 64 bit architectures but they don't get tested as often and thoroughly.
On Mon, Feb 15, 2021, 9:12 AM Kinsey Moore <kinsey.moore at oarcorp.com<mailto:kinsey.moore at oarcorp.com>> wrote:
From: ryan long <rlong at localhost.localdomain<mailto:rlong at localhost.localdomain>>
The ts-validation-0 test currently fails on 64bit BSPs due to a
limitation of the message structure. Changing the max message size to a
size_t type and adjusting the expected value in the test resolves this.
Closes #4179.
cpukit/include/rtems/rtems/message.h | 2 +-
cpukit/include/rtems/score/coremsgimpl.h | 2 +-
cpukit/score/src/coremsg.c | 2 +-
spec/build/bsps/aarch64/a53/tsta53.yml | 3 ---
spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml | 3 ---
testsuites/validation/tc-message-construct-errors.c | 2 +-
6 files changed, 4 insertions(+), 10 deletions(-)
diff --git a/cpukit/include/rtems/rtems/message.h b/cpukit/include/rtems/rtems/message.h
index 14083b8cd0..7bb48ba35a 100644
--- a/cpukit/include/rtems/rtems/message.h
+++ b/cpukit/include/rtems/rtems/message.h
@@ -51,7 +51,7 @@ typedef struct {
* @brief This member defines the maximum number of pending messages supported
* by the message queue.
- uint32_t maximum_pending_messages;
+ size_t maximum_pending_messages;
* @brief This member defines the maximum message size supported by the message
diff --git a/cpukit/include/rtems/score/coremsgimpl.h b/cpukit/include/rtems/score/coremsgimpl.h
index 6f6a01bea6..c7a424c08c 100644
--- a/cpukit/include/rtems/score/coremsgimpl.h
+++ b/cpukit/include/rtems/score/coremsgimpl.h
@@ -144,7 +144,7 @@ void *_CORE_message_queue_Workspace_allocate(
Status_Control _CORE_message_queue_Initialize(
CORE_message_queue_Control *the_message_queue,
CORE_message_queue_Disciplines discipline,
- uint32_t maximum_pending_messages,
+ size_t maximum_pending_messages,
size_t maximum_message_size,
CORE_message_queue_Allocate_buffers allocate_buffers,
const void *arg
diff --git a/cpukit/score/src/coremsg.c b/cpukit/score/src/coremsg.c
index cf7f44ed17..530f05719a 100644
--- a/cpukit/score/src/coremsg.c
+++ b/cpukit/score/src/coremsg.c
@@ -35,7 +35,7 @@ RTEMS_STATIC_ASSERT(
const void *arg
diff --git a/spec/build/bsps/aarch64/a53/tsta53.yml b/spec/build/bsps/aarch64/a53/tsta53.yml
index 9135fac7f4..4ecef03641 100644
--- a/spec/build/bsps/aarch64/a53/tsta53.yml
+++ b/spec/build/bsps/aarch64/a53/tsta53.yml
@@ -4,9 +4,6 @@ actions:
# expected to fail, don't compile these
minimum: exclude
- # test broken under 64bit due to SIZE_MAX differences
- validation-0: exclude
# don't compile due to toolchain issues
spconfig01: exclude
spmisc01: exclude
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
index d0efba65cd..45fdc503aa 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
# expected to fail
minimum: exclude
- validation-0: expected-fail
spconfig01: exclude
spmisc01: exclude
diff --git a/testsuites/validation/tc-message-construct-errors.c b/testsuites/validation/tc-message-construct-errors.c
index 5820855ac4..903ff534fa 100644
--- a/testsuites/validation/tc-message-construct-errors.c
+++ b/testsuites/validation/tc-message-construct-errors.c
@@ -278,7 +278,7 @@ static void RtemsMessageReqConstructErrors_Pre_MaxPending_Prepare(
case RtemsMessageReqConstructErrors_Pre_MaxPending_Big: {
- ctx->config.maximum_pending_messages = UINT32_MAX;
+ ctx->config.maximum_pending_messages = SIZE_MAX;
break;
2.20.1
devel mailing list
devel at rtems.org<mailto:devel at rtems.org>
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210215/5bf03e10/attachment-0001.html>
