[PATCH] tests/validation: Fix 64bit test failure
Chris Johns
chrisj at rtems.org
Mon Feb 15 20:24:36 UTC 2021
On 16/2/21 2:12 am, Kinsey Moore wrote:
> From: ryan long <rlong at localhost.localdomain>
The email address looks wrong to me.
> The ts-validation-0 test currently fails on 64bit BSPs due to a
> limitation of the message structure. Changing the max message size to a
> size_t type and adjusting the expected value in the test resolves this.
> Closes #4179.
> cpukit/include/rtems/rtems/message.h | 2 +-
> cpukit/include/rtems/score/coremsgimpl.h | 2 +-
> cpukit/score/src/coremsg.c | 2 +-
> spec/build/bsps/aarch64/a53/tsta53.yml | 3 ---
> spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml | 3 ---
> testsuites/validation/tc-message-construct-errors.c | 2 +-
> 6 files changed, 4 insertions(+), 10 deletions(-)
> diff --git a/cpukit/include/rtems/rtems/message.h b/cpukit/include/rtems/rtems/message.h
> index 14083b8cd0..7bb48ba35a 100644
> --- a/cpukit/include/rtems/rtems/message.h
> +++ b/cpukit/include/rtems/rtems/message.h
> @@ -51,7 +51,7 @@ typedef struct {
> * @brief This member defines the maximum number of pending messages supported
> * by the message queue.
> - uint32_t maximum_pending_messages;
> + size_t maximum_pending_messages;
> * @brief This member defines the maximum message size supported by the message
> diff --git a/cpukit/include/rtems/score/coremsgimpl.h b/cpukit/include/rtems/score/coremsgimpl.h
> index 6f6a01bea6..c7a424c08c 100644
> --- a/cpukit/include/rtems/score/coremsgimpl.h
> +++ b/cpukit/include/rtems/score/coremsgimpl.h
> @@ -144,7 +144,7 @@ void *_CORE_message_queue_Workspace_allocate(
> Status_Control _CORE_message_queue_Initialize(
> CORE_message_queue_Control *the_message_queue,
> CORE_message_queue_Disciplines discipline,
> - uint32_t maximum_pending_messages,
> + size_t maximum_pending_messages,
> size_t maximum_message_size,
> CORE_message_queue_Allocate_buffers allocate_buffers,
> const void *arg
> diff --git a/cpukit/score/src/coremsg.c b/cpukit/score/src/coremsg.c
> index cf7f44ed17..530f05719a 100644
> --- a/cpukit/score/src/coremsg.c
> +++ b/cpukit/score/src/coremsg.c
> @@ -35,7 +35,7 @@ RTEMS_STATIC_ASSERT(
> const void *arg
> diff --git a/spec/build/bsps/aarch64/a53/tsta53.yml b/spec/build/bsps/aarch64/a53/tsta53.yml
> index 9135fac7f4..4ecef03641 100644
> --- a/spec/build/bsps/aarch64/a53/tsta53.yml
> +++ b/spec/build/bsps/aarch64/a53/tsta53.yml
> @@ -4,9 +4,6 @@ actions:
> # expected to fail, don't compile these
> minimum: exclude
> - # test broken under 64bit due to SIZE_MAX differences
> - validation-0: exclude
> # don't compile due to toolchain issues
> spconfig01: exclude
> spmisc01: exclude
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
> index d0efba65cd..45fdc503aa 100644
> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
> # expected to fail
> minimum: exclude
> - validation-0: expected-fail
> spconfig01: exclude
> spmisc01: exclude
> diff --git a/testsuites/validation/tc-message-construct-errors.c b/testsuites/validation/tc-message-construct-errors.c
> index 5820855ac4..903ff534fa 100644
> --- a/testsuites/validation/tc-message-construct-errors.c
> +++ b/testsuites/validation/tc-message-construct-errors.c
> @@ -278,7 +278,7 @@ static void RtemsMessageReqConstructErrors_Pre_MaxPending_Prepare(
> case RtemsMessageReqConstructErrors_Pre_MaxPending_Big: {
> - ctx->config.maximum_pending_messages = UINT32_MAX;
> + ctx->config.maximum_pending_messages = SIZE_MAX;
> break;
