[PATCH v2] tests/validation: Fix 64bit test failure
Kinsey Moore
kinsey.moore at oarcorp.com
Mon Feb 15 20:44:01 UTC 2021
The email address got fixed here in v2. We were just responding on the original one.
Kinsey
-----Original Message-----
From: devel <devel-bounces at rtems.org> On Behalf Of Kinsey Moore
Sent: Monday, February 15, 2021 09:20
To: devel at rtems.org
Subject: [PATCH v2] tests/validation: Fix 64bit test failure
The ts-validation-0 test currently fails on 64bit BSPs due to a
limitation of the message structure. Changing the max message size to a
size_t type and adjusting the expected value in the test resolves this.
Closes #4179.
cpukit/include/rtems/rtems/message.h | 2 +-
cpukit/include/rtems/score/coremsgimpl.h | 2 +-
cpukit/score/src/coremsg.c | 2 +-
spec/build/bsps/aarch64/a53/tsta53.yml | 3 ---
spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml | 3 ---
testsuites/validation/tc-message-construct-errors.c | 2 +-
6 files changed, 4 insertions(+), 10 deletions(-)
diff --git a/cpukit/include/rtems/rtems/message.h b/cpukit/include/rtems/rtems/message.h
index 14083b8cd0..7bb48ba35a 100644
--- a/cpukit/include/rtems/rtems/message.h
+++ b/cpukit/include/rtems/rtems/message.h
@@ -51,7 +51,7 @@ typedef struct {
* @brief This member defines the maximum number of pending messages supported
* by the message queue.
- uint32_t maximum_pending_messages;
+ size_t maximum_pending_messages;
* @brief This member defines the maximum message size supported by the message
diff --git a/cpukit/include/rtems/score/coremsgimpl.h b/cpukit/include/rtems/score/coremsgimpl.h
index 6f6a01bea6..c7a424c08c 100644
--- a/cpukit/include/rtems/score/coremsgimpl.h
+++ b/cpukit/include/rtems/score/coremsgimpl.h
@@ -144,7 +144,7 @@ void *_CORE_message_queue_Workspace_allocate(
Status_Control _CORE_message_queue_Initialize(
CORE_message_queue_Control *the_message_queue,
CORE_message_queue_Disciplines discipline,
- uint32_t maximum_pending_messages,
+ size_t maximum_pending_messages,
size_t maximum_message_size,
CORE_message_queue_Allocate_buffers allocate_buffers,
const void *arg
diff --git a/cpukit/score/src/coremsg.c b/cpukit/score/src/coremsg.c
index cf7f44ed17..530f05719a 100644
--- a/cpukit/score/src/coremsg.c
+++ b/cpukit/score/src/coremsg.c
@@ -35,7 +35,7 @@ RTEMS_STATIC_ASSERT(
const void *arg
diff --git a/spec/build/bsps/aarch64/a53/tsta53.yml b/spec/build/bsps/aarch64/a53/tsta53.yml
index 9135fac7f4..4ecef03641 100644
--- a/spec/build/bsps/aarch64/a53/tsta53.yml
+++ b/spec/build/bsps/aarch64/a53/tsta53.yml
@@ -4,9 +4,6 @@ actions:
# expected to fail, don't compile these
minimum: exclude
- # test broken under 64bit due to SIZE_MAX differences
- validation-0: exclude
# don't compile due to toolchain issues
spconfig01: exclude
spmisc01: exclude
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
index d0efba65cd..45fdc503aa 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
# expected to fail
minimum: exclude
- validation-0: expected-fail
spconfig01: exclude
spmisc01: exclude
diff --git a/testsuites/validation/tc-message-construct-errors.c b/testsuites/validation/tc-message-construct-errors.c
index 5820855ac4..903ff534fa 100644
--- a/testsuites/validation/tc-message-construct-errors.c
+++ b/testsuites/validation/tc-message-construct-errors.c
@@ -278,7 +278,7 @@ static void RtemsMessageReqConstructErrors_Pre_MaxPending_Prepare(
case RtemsMessageReqConstructErrors_Pre_MaxPending_Big: {
- ctx->config.maximum_pending_messages = UINT32_MAX;
+ ctx->config.maximum_pending_messages = SIZE_MAX;
break;
2.20.1
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
