[PATCH v2] tests/validation: Fix 64bit test failure
Martin Erik Werner martinerikwerner.aac at gmail.com
Mon Feb 15 21:34:48 UTC 2021
On Mon, 2021-02-15 at 09:19 -0600, Kinsey Moore wrote:
> From: Ryan Long <ryan.long at oarcorp.com>
> The ts-validation-0 test currently fails on 64bit BSPs due to a
> limitation of the message structure. Changing the max message size to a
> size_t type and adjusting the expected value in the test resolves this.
This talks about the message size, but the change is to the pending
count?
> Closes #4179.
This seems to be the wrong bug reference, is #4197 the correct one?
If this change is correct there are a couple of casts left over now
which maybe should be adjusted as well?:
cpukit/score/src/coremsg.c:64:    (size_t) maximum_pending_messages * buffer_size,
cpukit/score/src/coremsg.c:89:    (size_t) maximum_pending_messages,
I'm however wondering if this is the right way to fix this...
I'm guessing that the failure mentioned is based on this specification
in rtems-central : spec/rtems/message/req/construct-errors.yml
393	- enabled-by: true
394	  post-conditions:
395	    Status: InvNum
396	  pre-conditions:
397	    Area: all
398	    AreaSize: all
399	    Id:
400	    - Id
401	    MaxPending:
402	    - Big
403	    MaxSize:
404	    - Valid
405	    Name:
406	    - Valid
407	    Queues:
408	    - Avail
Which in practice seems to specify that
rtems_message_queue_create
name,
UINT32_MAX /* count */,
1 /* size */,
attribute_set,
&id
must fail with RTEMS_INVALID_NUMBER due to
117  - name: Big
118    test-code: |
119      ctx->config.maximum_pending_messages = UINT32_MAX;
120    text: |
121      The maximum number of pending messages of the message queue configuration
122      shall be big enough so that a calculation to get the message buffer
123      storage area size overflows.
which in the code looks like
/* Make sure the memory allocation size computation does not overflow */
if ( maximum_pending_messages > SIZE_MAX / buffer_size ) {
  return STATUS_MESSAGE_QUEUE_INVALID_NUMBER;
But when the SIZE_MAX is a 64bit size_t, then UINT32_MAX * (1 + buffer
overhead) cannot reasonably overflow SIZE_MAX, so this will report
success instead of the expected invalid number which is the failure
seen in the validation test, is that correct?
If so, it seems very odd to change the interface just to allow this
failure to occur.
Would it be possible to instead specify that if
SIZE_MAX >= UINT32_MAX * (1 + buffer overhead)
then this case should be skipped, or expects success?
Martin Erik Werner
Software Developer | AAC Clyde Space
aac-clydespace.com/privacy-policy
