[PATCH v3 1/3] bsps/xilinx_zynq: Add SPI driver for cadence-spi
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Tue Feb 16 15:47:22 UTC 2021
> -----Original Message-----
> From: dufault at hda.com <dufault at hda.com>
> Sent: Tuesday, February 16, 2021 2:05 PM
> To: Sommer, Jan <Jan.Sommer at dlr.de>
> Cc: joel at rtems.org; devel at rtems.org
> Subject: Re: [PATCH v3 1/3] bsps/xilinx_zynq: Add SPI driver for cadence-spi
> You could use "fuer" to replace "für" as was done in the olden days.  Or do
> you need permission for that as well?
The umlaut is part of the official brand.
That can be tricky, depending on the corporate policy.
> I find it odd to avoid Unicode and not allow umlauts in 2021.
Yes. Luckily my parents gave me an ASCII-compatible name.
Saves a lot of trouble  :-)
Best regards,
    Jan
> > On Feb 16, 2021, at 05:21 , Jan.Sommer at dlr.de wrote:
> > Ok, I asked if it is ok to use the English name for our organization as well.
> > The answer might take some time, though.
> > Best regards,
> >     Jan
> > From: Joel Sherrill <joel at rtems.org>
> > Sent: Monday, February 15, 2021 9:41 PM
> > To: Peter Dufault <dufault at hda.com>
> > Cc: Sommer, Jan <Jan.Sommer at dlr.de>; rtems-devel at rtems.org
> > <devel at rtems.org>
> > cadence-spi
> > Christian submitted a series of patches to eliminate unicode. I'd
> > prefer if we avoided it
> > On Mon, Feb 15, 2021, 8:20 AM Peter Dufault <dufault at hda.com> wrote:
> > An international project should allow UTF in source code.  You might need
> to hunt what setting you need (for gnome-terminal "export
> LANG=en_US.UTF-8" works for me in the US).  I'm surprised if anyone is
> working on a system that can't at least display UTF-8.
> > > On Feb 15, 2021, at 03:21 , Jan.Sommer at dlr.de wrote:
> > > Hi Chris,
> > >> From: Chris Johns <chrisj at rtems.org>
> > >> Sent: Sunday, February 14, 2021 10:20 PM
> > >> To: Sommer, Jan <Jan.Sommer at dlr.de>; devel at rtems.org
> > >> cadence-spi
> > >> Hi Jan,
> > >> Thank you for the changes. I have one question inlined below ...
> > >> On 14/2/21 10:30 pm, Jan Sommer wrote:
> > >>> bsps/include/dev/spi/cadence-spi-regs.h |  84 +++++
> > >>> bsps/include/dev/spi/cadence-spi.h      |  48 +++
> > >>> bsps/shared/dev/spi/cadence-spi.c       | 437
> > >>> 3 files changed, 569 insertions(+) create mode 100644
> > >>> create mode 100644 bsps/include/dev/spi/cadence-spi.h
> > >>> create mode 100644 bsps/shared/dev/spi/cadence-spi.c
> > >>> diff --git a/bsps/include/dev/spi/cadence-spi-regs.h
> > >>> b/bsps/include/dev/spi/cadence-spi-regs.h
> > >>> new file mode 100644
> > >>> index 0000000000..2851c88df1
> > >>> --- /dev/null
> > >>> +++ b/bsps/include/dev/spi/cadence-spi-regs.h
> > >>> @@ -0,0 +1,84 @@
> > >>> +/* SPDX-License-Identifier: BSD-2-Clause */
> > >>> + * Copyright (C) 2020 Jan Sommer, Deutsches Zentrum für Luft- und
> > >> Raumfahrt e. V.
> > >> Is there a unicode character in this line? I cannot see anything in
> > >> our coding standard about unicode characters in source and I am not
> > >> sure what the actual policy is. I seem to remember some have been
> > >> removed in the past. I thought I would ask on the list now before we
> push these changes.
> > > There is an u-Umlaut in it. That is probably it. As it is part of the name, it's
> hard to get rid of.
> > > I could probably use the English name (German Aerospace Center) which
> has no special characters.
> > > Would that be preferred?
> > > Best regards,
> > >    Jan
> > >> Chris
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/devel
> > Peter
> > Peter Dufault
> > HD Associates, Inc.      Software and System Engineering
> > This email is delivered through the public internet using protocols subject
> to interception and tampering.
> > devel mailing list
> > devel at rtems.org
> Peter
> Peter Dufault
> This email is delivered through the public internet using protocols subject to
