[PATCH v3 1/3] bsps/xilinx_zynq: Add SPI driver for cadence-spi
Gedare Bloom
gedare at rtems.org
Tue Feb 16 16:33:57 UTC 2021
On Tue, Feb 16, 2021 at 8:47 AM <Jan.Sommer at dlr.de> wrote:
> > -----Original Message-----
> > From: dufault at hda.com <dufault at hda.com>
> > Sent: Tuesday, February 16, 2021 2:05 PM
> > To: Sommer, Jan <Jan.Sommer at dlr.de>
> > Cc: joel at rtems.org; devel at rtems.org
> > Subject: Re: [PATCH v3 1/3] bsps/xilinx_zynq: Add SPI driver for cadence-spi
> > You could use "fuer" to replace "für" as was done in the olden days. Or do
> > you need permission for that as well?
> The umlaut is part of the official brand.
> That can be tricky, depending on the corporate policy.
> > I find it odd to avoid Unicode and not allow umlauts in 2021.
We do allow unicode with justification. For names, I have no problem
with unicode characters. We do need to confirm when it commits, that
it comes back out the other side properly and doesn't become mangled
by some ASCII conversion.
> Yes. Luckily my parents gave me an ASCII-compatible name.
> Saves a lot of trouble :-)
> Best regards,
> Jan
> > > On Feb 16, 2021, at 05:21 , Jan.Sommer at dlr.de wrote:
> > > Ok, I asked if it is ok to use the English name for our organization as well.
> > > The answer might take some time, though.
> > > Best regards,
> > > Jan
> > > From: Joel Sherrill <joel at rtems.org>
> > > Sent: Monday, February 15, 2021 9:41 PM
> > > To: Peter Dufault <dufault at hda.com>
> > > Cc: Sommer, Jan <Jan.Sommer at dlr.de>; rtems-devel at rtems.org
> > > <devel at rtems.org>
> > > cadence-spi
> > > Christian submitted a series of patches to eliminate unicode. I'd
> > > prefer if we avoided it
> > > On Mon, Feb 15, 2021, 8:20 AM Peter Dufault <dufault at hda.com> wrote:
> > > An international project should allow UTF in source code. You might need
> > to hunt what setting you need (for gnome-terminal "export
> > LANG=en_US.UTF-8" works for me in the US). I'm surprised if anyone is
> > working on a system that can't at least display UTF-8.
> > > > On Feb 15, 2021, at 03:21 , Jan.Sommer at dlr.de wrote:
> > > > Hi Chris,
> > > >> From: Chris Johns <chrisj at rtems.org>
> > > >> Sent: Sunday, February 14, 2021 10:20 PM
> > > >> To: Sommer, Jan <Jan.Sommer at dlr.de>; devel at rtems.org
> > > >> cadence-spi
> > > >> Hi Jan,
> > > >> Thank you for the changes. I have one question inlined below ...
> > > >> On 14/2/21 10:30 pm, Jan Sommer wrote:
> > > >>> bsps/include/dev/spi/cadence-spi-regs.h | 84 +++++
> > > >>> bsps/include/dev/spi/cadence-spi.h | 48 +++
> > > >>> bsps/shared/dev/spi/cadence-spi.c | 437
> > > >>> 3 files changed, 569 insertions(+) create mode 100644
> > > >>> create mode 100644 bsps/include/dev/spi/cadence-spi.h
> > > >>> create mode 100644 bsps/shared/dev/spi/cadence-spi.c
> > > >>> diff --git a/bsps/include/dev/spi/cadence-spi-regs.h
> > > >>> b/bsps/include/dev/spi/cadence-spi-regs.h
> > > >>> new file mode 100644
> > > >>> index 0000000000..2851c88df1
> > > >>> --- /dev/null
> > > >>> +++ b/bsps/include/dev/spi/cadence-spi-regs.h
> > > >>> @@ -0,0 +1,84 @@
> > > >>> +/* SPDX-License-Identifier: BSD-2-Clause */
> > > >>> + * Copyright (C) 2020 Jan Sommer, Deutsches Zentrum für Luft- und
> > > >> Raumfahrt e. V.
> > > >> Is there a unicode character in this line? I cannot see anything in
> > > >> our coding standard about unicode characters in source and I am not
> > > >> sure what the actual policy is. I seem to remember some have been
> > > >> removed in the past. I thought I would ask on the list now before we
> > push these changes.
> > > > There is an u-Umlaut in it. That is probably it. As it is part of the name, it's
> > hard to get rid of.
> > > > I could probably use the English name (German Aerospace Center) which
> > has no special characters.
> > > > Would that be preferred?
> > > > Best regards,
> > > > Jan
> > > >> Chris
> > > > _______________________________________________
> > > > devel mailing list
> > > > devel at rtems.org
> > > > http://lists.rtems.org/mailman/listinfo/devel
> > > Peter
> > > Peter Dufault
> > > HD Associates, Inc. Software and System Engineering
> > > This email is delivered through the public internet using protocols subject
> > to interception and tampering.
> > > devel mailing list
> > > devel at rtems.org
> > Peter
> > Peter Dufault
> > This email is delivered through the public internet using protocols subject to
> devel mailing list
> devel at rtems.org
