[PATCH 05/13] posix: Remove superfluous check
Wed Feb 17 19:30:20 UTC 2021
The api pointer is never NULL.
Update #4244.
 cpukit/posix/src/psignalunblockthread.c | 6 ------
 1 file changed, 6 deletions(-)
diff --git a/cpukit/posix/src/psignalunblockthread.c b/cpukit/posix/src/psignalunblockthread.c
index 63ed823ab3..a1af20a5af 100644
--- a/cpukit/posix/src/psignalunblockthread.c
+++ b/cpukit/posix/src/psignalunblockthread.c
@@ -111,12 +111,6 @@ static void _POSIX_signals_Action_handler(
   hold_errno = executing->Wait.return_code;
-   * api may be NULL in case of a thread close in progress
-  if ( !api )
-    return;
    *  In case the executing thread is blocked or about to block on something
    *  that uses the thread wait information, then this is a kernel bug.
2.26.2
