[PATCH 05/13] posix: Remove superfluous check
Gedare Bloom
gedare at rtems.org
Thu Feb 18 17:21:30 UTC 2021
On Wed, Feb 17, 2021 at 12:31 PM Sebastian Huber
> The api pointer is never NULL.
> Update #4244.
> cpukit/posix/src/psignalunblockthread.c | 6 ------
> 1 file changed, 6 deletions(-)
> diff --git a/cpukit/posix/src/psignalunblockthread.c b/cpukit/posix/src/psignalunblockthread.c
> index 63ed823ab3..a1af20a5af 100644
> --- a/cpukit/posix/src/psignalunblockthread.c
> +++ b/cpukit/posix/src/psignalunblockthread.c
> @@ -111,12 +111,6 @@ static void _POSIX_signals_Action_handler(
> hold_errno = executing->Wait.return_code;
> - * api may be NULL in case of a thread close in progress
> - if ( !api )
> - return;
I believe you, but should we replace this with an assert for now?
> * In case the executing thread is blocked or about to block on something
> * that uses the thread wait information, then this is a kernel bug.
> 2.26.2
> devel mailing list
> devel at rtems.org
