Fwd: Buildbot failure in RTEMS on powerpc/psim FreeBSD 10.1-STABLE GCC 7.3.0 POSIX
Wed Feb 17 20:56:42 UTC 2021
On 18/2/21 7:18 am, Joel Sherrill wrote:
> Any idea why psim fails on buildbot but not the other BSPs run through buildbot?
> Did Amar miss updating the powerpc tools?
Autoconf vs waf? Buildbot is still on autoconf.
> ---------- Forwarded message ---------
> From: <buildbot at rtems.org <mailto:buildbot at rtems.org>>
> Date: Wed, Feb 17, 2021 at 2:02 PM
> Subject: Buildbot failure in RTEMS on powerpc/psim FreeBSD 10.1-STABLE GCC 7.3.0
> POSIX
> To: <build at rtems.org <mailto:build at rtems.org>>
> The Buildbot has detected a failed build on builder powerpc/psim FreeBSD
> 10.1-STABLE GCC 7.3.0 POSIX while building rtems.
> Full details are available at:
>     https://buildbot.rtems.org/#builders/19/builds/429
> <https://buildbot.rtems.org/#builders/19/builds/429>
> Buildbot URL: https://buildbot.rtems.org/ <https://buildbot.rtems.org/>
> Worker for this Build: build-1
> Build Reason: <unknown>
> Blamelist: Chris Johns <chrisj at rtems.org <mailto:chrisj at rtems.org>>, G S Niteesh
> Babu <niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>>, Ryan Long
> <ryan.long at oarcorp.com <mailto:ryan.long at oarcorp.com>>, Sebastian Huber
> <sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>>
> BUILD FAILED: failed make (failure)
> Sincerely,
>  -The Buildbot
> build mailing list
> http://lists.rtems.org/mailman/listinfo/build
> <http://lists.rtems.org/mailman/listinfo/build>
> devel mailing list
> devel at rtems.org
