Fwd: Buildbot failure in RTEMS on powerpc/psim FreeBSD 10.1-STABLE GCC 7.3.0 POSIX
Joel Sherrill
joel at rtems.org
Wed Feb 17 21:11:51 UTC 2021
On Wed, Feb 17, 2021, 2:56 PM Chris Johns <chrisj at rtems.org> wrote:
> On 18/2/21 7:18 am, Joel Sherrill wrote:
> > Any idea why psim fails on buildbot but not the other BSPs run through
> buildbot?
> > Did Amar miss updating the powerpc tools?
> Autoconf vs waf? Buildbot is still on autoconf.
That's it. PowerPC is broken on master for autoconf. :(
> Chris
> > ---------- Forwarded message ---------
> > From: <buildbot at rtems.org <mailto:buildbot at rtems.org>>
> > Date: Wed, Feb 17, 2021 at 2:02 PM
> > Subject: Buildbot failure in RTEMS on powerpc/psim FreeBSD 10.1-STABLE
> GCC 7.3.0
> > POSIX
> > To: <build at rtems.org <mailto:build at rtems.org>>
> > The Buildbot has detected a failed build on builder powerpc/psim FreeBSD
> > 10.1-STABLE GCC 7.3.0 POSIX while building rtems.
> > Full details are available at:
> > https://buildbot.rtems.org/#builders/19/builds/429
> > <https://buildbot.rtems.org/#builders/19/builds/429>
> > Buildbot URL: https://buildbot.rtems.org/ <https://buildbot.rtems.org/>
> > Worker for this Build: build-1
> > Build Reason: <unknown>
> > Blamelist: Chris Johns <chrisj at rtems.org <mailto:chrisj at rtems.org>>, G
> S Niteesh
> > Babu <niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>>, Ryan Long
> > <ryan.long at oarcorp.com <mailto:ryan.long at oarcorp.com>>, Sebastian Huber
> > <sebastian.huber at embedded-brains.de <mailto:
> sebastian.huber at embedded-brains.de>>
> > BUILD FAILED: failed make (failure)
> > Sincerely,
> > -The Buildbot
> > build mailing list
> > http://lists.rtems.org/mailman/listinfo/build
> > <http://lists.rtems.org/mailman/listinfo/build>
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210217/6c5af86b/attachment.html>
