Fwd: Buildbot failure in RTEMS on powerpc/psim FreeBSD 10.1-STABLE GCC 7.3.0 POSIX
Wed Feb 17 21:59:45 UTC 2021
On Wed, Feb 17, 2021 at 3:36 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Feb 17, 2021 at 2:12 PM Joel Sherrill <joel at rtems.org> wrote:
> > On Wed, Feb 17, 2021, 2:56 PM Chris Johns <chrisj at rtems.org> wrote:
> >> On 18/2/21 7:18 am, Joel Sherrill wrote:
> >> > Any idea why psim fails on buildbot but not the other BSPs run
> through buildbot?
> >> > Did Amar miss updating the powerpc tools?
> >> Autoconf vs waf? Buildbot is still on autoconf.
> > That's it. PowerPC is broken on master for autoconf. :(
> kill it!!
> ok, what has to be done to make some people happy with cutting us off
> from autotools?
As the proud representative of the "some people", there were only two things
on the list until BuildBot added itself.
+ rtems-bsp-builder
+ build bot
+ rtems kernel RSB
Some fine people ordered them that way because the first two are critical
for our automated testing builds. The last one is important and user facing
but it might be a candidate for after removing autoconf. Breaks
RTEMS packaging via RSB
The "some people" were as happy with the state of the BSPs on autoconf
vs waf as is possible.
--joel
> >> Chris
> >> > ---------- Forwarded message ---------
> >> > From: <buildbot at rtems.org <mailto:buildbot at rtems.org>>
> >> > Date: Wed, Feb 17, 2021 at 2:02 PM
> >> > Subject: Buildbot failure in RTEMS on powerpc/psim FreeBSD
> >> > POSIX
> >> > To: <build at rtems.org <mailto:build at rtems.org>>
> >> > The Buildbot has detected a failed build on builder powerpc/psim
> FreeBSD
> >> > 10.1-STABLE GCC 7.3.0 POSIX while building rtems.
> >> > Full details are available at:
> >> >     https://buildbot.rtems.org/#builders/19/builds/429
> >> > <https://buildbot.rtems.org/#builders/19/builds/429>
> >> > Buildbot URL: https://buildbot.rtems.org/ <
> https://buildbot.rtems.org/>
> >> > Worker for this Build: build-1
> >> > Build Reason: <unknown>
> >> > Blamelist: Chris Johns <chrisj at rtems.org <mailto:chrisj at rtems.org>>,
> G S Niteesh
> >> > Babu <niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>>, Ryan Long
> >> > <ryan.long at oarcorp.com <mailto:ryan.long at oarcorp.com>>, Sebastian
> Huber
> >> > <sebastian.huber at embedded-brains.de <mailto:
> sebastian.huber at embedded-brains.de>>
> >> > BUILD FAILED: failed make (failure)
> >> > Sincerely,
> >> >  -The Buildbot
> >> > _______________________________________________
> >> > build mailing list
> >> > http://lists.rtems.org/mailman/listinfo/build
> >> > <http://lists.rtems.org/mailman/listinfo/build>
> >> > devel mailing list
> >> > devel at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210217/a45f93f4/attachment-0001.html>
