Fwd: Buildbot failure in RTEMS on powerpc/psim FreeBSD 10.1-STABLE GCC 7.3.0 POSIX
Wed Feb 17 21:36:18 UTC 2021
On Wed, Feb 17, 2021 at 2:12 PM Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Feb 17, 2021, 2:56 PM Chris Johns <chrisj at rtems.org> wrote:
>> On 18/2/21 7:18 am, Joel Sherrill wrote:
>> > Any idea why psim fails on buildbot but not the other BSPs run through buildbot?
>> > Did Amar miss updating the powerpc tools?
>> Autoconf vs waf? Buildbot is still on autoconf.
> That's it. PowerPC is broken on master for autoconf. :(
kill it!!
ok, what has to be done to make some people happy with cutting us off
from autotools?
>> Chris
>> > ---------- Forwarded message ---------
>> > From: <buildbot at rtems.org <mailto:buildbot at rtems.org>>
>> > Date: Wed, Feb 17, 2021 at 2:02 PM
>> > Subject: Buildbot failure in RTEMS on powerpc/psim FreeBSD 10.1-STABLE GCC 7.3.0
>> > POSIX
>> > To: <build at rtems.org <mailto:build at rtems.org>>
>> > The Buildbot has detected a failed build on builder powerpc/psim FreeBSD
>> > 10.1-STABLE GCC 7.3.0 POSIX while building rtems.
>> > Full details are available at:
>> >     https://buildbot.rtems.org/#builders/19/builds/429
>> > <https://buildbot.rtems.org/#builders/19/builds/429>
>> > Buildbot URL: https://buildbot.rtems.org/ <https://buildbot.rtems.org/>
>> > Worker for this Build: build-1
>> > Build Reason: <unknown>
>> > Blamelist: Chris Johns <chrisj at rtems.org <mailto:chrisj at rtems.org>>, G S Niteesh
>> > Babu <niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>>, Ryan Long
>> > <ryan.long at oarcorp.com <mailto:ryan.long at oarcorp.com>>, Sebastian Huber
>> > <sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>>
>> > BUILD FAILED: failed make (failure)
>> > Sincerely,
>> >  -The Buildbot
>> > _______________________________________________
>> > build mailing list
>> > http://lists.rtems.org/mailman/listinfo/build
>> > <http://lists.rtems.org/mailman/listinfo/build>
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
