[PATCH 11/13] rtems: New errors for rtems_signal_catch()
Gedare Bloom
gedare at rtems.org
Thu Feb 18 17:32:06 UTC 2021
On Wed, Feb 17, 2021 at 12:30 PM Sebastian Huber
> Ensure that no invalid modes are set during ASR processing.
> Update #4244.
> cpukit/rtems/src/signalcatch.c | 27 +++++++++++++++++++++++++++
> 1 file changed, 27 insertions(+)
> diff --git a/cpukit/rtems/src/signalcatch.c b/cpukit/rtems/src/signalcatch.c
> index 8ee22e5ec1..da56d26dc5 100644
> --- a/cpukit/rtems/src/signalcatch.c
> +++ b/cpukit/rtems/src/signalcatch.c
> @@ -22,7 +22,10 @@
> #endif
> #include <rtems/rtems/signalimpl.h>
> +#include <rtems/rtems/modesimpl.h>
> #include <rtems/rtems/tasksdata.h>
> +#include <rtems/score/schedulerimpl.h>
> +#include <rtems/score/smpimpl.h>
> #include <rtems/score/threadimpl.h>
> RTEMS_STATIC_ASSERT( RTEMS_DEFAULT_MODES == 0, _ASR_Create_mode_set );
> @@ -37,7 +40,31 @@ rtems_status_code rtems_signal_catch(
> ASR_Information *asr;
> ISR_lock_Context lock_context;
> +#if defined(RTEMS_SMP) || CPU_ENABLE_ROBUST_THREAD_DISPATCH == TRUE
> + if (
> + _Modes_Get_interrupt_level( mode_set ) != 0
> +#if CPU_ENABLE_ROBUST_THREAD_DISPATCH == FALSE
> + && _SMP_Need_inter_processor_interrupts()
> +#endif
> + return RTEMS_NOT_IMPLEMENTED;
> +#endif
> executing = _Thread_State_acquire_for_executing( &lock_context );
add a brief comment here, the logic a little complicated with
double-negatives, e.g.,
/* Check for non-preempt mode requested with a scheduler that does not
support non-preemption */
> + if (
> + !_Modes_Is_preempt( mode_set ) &&
> + !_Scheduler_Is_non_preempt_mode_supported(
no indent (align the !)
> + _Thread_Scheduler_get_home( executing )
> + _Thread_State_release( executing, &lock_context );
> +#endif
> api = executing->API_Extensions[ THREAD_API_RTEMS ];
> asr = &api->Signal;
> asr->handler = asr_handler;
> 2.26.2
> devel mailing list
> devel at rtems.org
