[PATCH 11/13] rtems: New errors for rtems_signal_catch()
Thu Feb 18 19:29:02 UTC 2021
On Thu, Feb 18, 2021 at 11:32 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Feb 17, 2021 at 12:30 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > Ensure that no invalid modes are set during ASR processing.
> > Update #4244.
> >  cpukit/rtems/src/signalcatch.c | 27 +++++++++++++++++++++++++++
> >  1 file changed, 27 insertions(+)
> > diff --git a/cpukit/rtems/src/signalcatch.c
> b/cpukit/rtems/src/signalcatch.c
> > index 8ee22e5ec1..da56d26dc5 100644
> > --- a/cpukit/rtems/src/signalcatch.c
> > +++ b/cpukit/rtems/src/signalcatch.c
> > @@ -22,7 +22,10 @@
> >  #endif
> >  #include <rtems/rtems/signalimpl.h>
> > +#include <rtems/rtems/modesimpl.h>
> >  #include <rtems/rtems/tasksdata.h>
> > +#include <rtems/score/schedulerimpl.h>
> > +#include <rtems/score/smpimpl.h>
> >  #include <rtems/score/threadimpl.h>
> >  RTEMS_STATIC_ASSERT( RTEMS_DEFAULT_MODES == 0, _ASR_Create_mode_set );
> > @@ -37,7 +40,31 @@ rtems_status_code rtems_signal_catch(
> >    ASR_Information    *asr;
> >    ISR_lock_Context    lock_context;
> > +#if defined(RTEMS_SMP) || CPU_ENABLE_ROBUST_THREAD_DISPATCH == TRUE
> > +  if (
> > +    _Modes_Get_interrupt_level( mode_set ) != 0
> > +#if CPU_ENABLE_ROBUST_THREAD_DISPATCH == FALSE
> > +      && _SMP_Need_inter_processor_interrupts()
> > +#endif
> > +    return RTEMS_NOT_IMPLEMENTED;
> > +#endif
> >    executing = _Thread_State_acquire_for_executing( &lock_context );
> add a brief comment here, the logic a little complicated with
> double-negatives, e.g.,
> /* Check for non-preempt mode requested with a scheduler that does not
> support non-preemption */
I think I have seen a very similar check in other places. Can this
combination
of logic be turned into a macro which has a better name?
> > +  if (
> > +    !_Modes_Is_preempt( mode_set ) &&
> > +      !_Scheduler_Is_non_preempt_mode_supported(
> no indent (align the !)
> > +        _Thread_Scheduler_get_home( executing )
> > +    _Thread_State_release( executing, &lock_context );
> > +#endif
> >    api = executing->API_Extensions[ THREAD_API_RTEMS ];
> >    asr = &api->Signal;
> >    asr->handler = asr_handler;
> > 2.26.2
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210218/b4b093aa/attachment.html>
