[PATCH 13/13] rtems: Avoid potential recursion in ASR handling
Fri Feb 19 06:58:57 UTC 2021
On 18/02/2021 18:49, Gedare Bloom wrote:
>> +  executing->cpu_time_budget = normal_cpu_time_budget ;
>> +  executing->budget_algorithm = normal_budget_algorithm ;
>> +  prev_is_preemptible = executing->is_preemptible;
> 'prev' is unclear here, especially since we have "normal" as a
> previous mode also. Maybe, 'asr_is_preemptible' is better?
No, normal is not necessarily the previous mode. The ASR handler may
change the mode. I can name it previous_is_preemptible if you don't like
the prev. asr_is_preemptible doesn't fit, since this is the mode set up
before the ASR handler is called.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
