[PATCH 13/13] rtems: Avoid potential recursion in ASR handling
Fri Feb 19 16:35:51 UTC 2021
On Thu, Feb 18, 2021 at 11:59 PM Sebastian Huber
> On 18/02/2021 18:49, Gedare Bloom wrote:
> >> +  executing->cpu_time_budget = normal_cpu_time_budget ;
> >> +  executing->budget_algorithm = normal_budget_algorithm ;
> >> +  prev_is_preemptible = executing->is_preemptible;
> > 'prev' is unclear here, especially since we have "normal" as a
> > previous mode also. Maybe, 'asr_is_preemptible' is better?
> No, normal is not necessarily the previous mode. The ASR handler may
> change the mode. I can name it previous_is_preemptible if you don't like
> the prev. asr_is_preemptible doesn't fit, since this is the mode set up
> before the ASR handler is called.
I guess I just get a little confused between what "previous" means in
this case. Normal mode is "previous" to the ASR call, and you are
copying the executing->is_preemptible that may have been changed by
the ASR, so what is this "previous" to? It doesn't make sense to me.
I don't mind 'prev' as an abbreviation of previous. I just don't know
what this is_preemptible variable is "previous" to?
I guess there are three points here...
Before the ASR
In the ASR
Dispatching after the ASR
Returning to the original caller
So, you can't say "previous" since there are 2 things in the middle.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
