[PATCH 3/6] score: Remove _CORE_barrier_Do_flush()
Mon Feb 22 08:43:46 UTC 2021
Call _Thread_queue_Flush_critical() directly.
 cpukit/Makefile.am                           |  1 -
 cpukit/include/rtems/score/corebarrierimpl.h | 23 ++++--------
 cpukit/score/src/corebarrierrelease.c        | 37 --------------------
 spec/build/cpukit/librtemscpu.yml            |  1 -
 4 files changed, 6 insertions(+), 56 deletions(-)
 delete mode 100644 cpukit/score/src/corebarrierrelease.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 14abc8bb6a..a31cd31596 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -833,7 +833,6 @@ librtemscpu_a_SOURCES += score/src/apimutexisowner.c
 librtemscpu_a_SOURCES += score/src/apimutexlock.c
 librtemscpu_a_SOURCES += score/src/apimutexunlock.c
 librtemscpu_a_SOURCES += score/src/corebarrier.c
-librtemscpu_a_SOURCES += score/src/corebarrierrelease.c
 librtemscpu_a_SOURCES += score/src/corebarrierwait.c
 librtemscpu_a_SOURCES += score/src/coremsg.c
 librtemscpu_a_SOURCES += score/src/coremsgbroadcast.c
diff --git a/cpukit/include/rtems/score/corebarrierimpl.h b/cpukit/include/rtems/score/corebarrierimpl.h
index 86a3e956dc..4e7f07d8e9 100644
--- a/cpukit/include/rtems/score/corebarrierimpl.h
+++ b/cpukit/include/rtems/score/corebarrierimpl.h
@@ -127,19 +127,6 @@ Status_Control _CORE_barrier_Seize(
   Thread_queue_Context *queue_context
- * @brief Flushes the barrier.
- * @param[in, out] the_barrier The barrier to flush.
- * @param[out] filter The filter for flushing.
- * @param[out] queue_context The thread queue context.
-uint32_t _CORE_barrier_Do_flush(
-  CORE_barrier_Control      *the_barrier,
-  Thread_queue_Flush_filter  filter,
-  Thread_queue_Context      *queue_context
  * @brief Manually releases the barrier.
@@ -156,8 +143,9 @@ RTEMS_INLINE_ROUTINE uint32_t _CORE_barrier_Surrender(
-  return _CORE_barrier_Do_flush(
-    the_barrier,
+  return _Thread_queue_Flush_critical(
+    &the_barrier->Wait_queue.Queue,
+    &_CORE_barrier_Thread_queue_operations,
     _Thread_queue_Flush_default_filter,
     queue_context
@@ -174,8 +162,9 @@ RTEMS_INLINE_ROUTINE void _CORE_barrier_Flush(
-  _CORE_barrier_Do_flush(
-    the_barrier,
+  _Thread_queue_Flush_critical(
     _Thread_queue_Flush_status_object_was_deleted,
     queue_context
diff --git a/cpukit/score/src/corebarrierrelease.c b/cpukit/score/src/corebarrierrelease.c
deleted file mode 100644
index 3202171e7f..0000000000
--- a/cpukit/score/src/corebarrierrelease.c
+++ /dev/null
@@ -1,37 +0,0 @@
- * @file
- * @ingroup RTEMSScoreBarrier
- * @brief This source file contains the implementation of
- *   _CORE_barrier_Do_flush().
- *  COPYRIGHT (c) 1989-2006.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/score/corebarrierimpl.h>
-  return _Thread_queue_Flush_critical(
-    &the_barrier->Wait_queue.Queue,
-    &_CORE_barrier_Thread_queue_operations,
-    filter,
-    queue_context
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 3d1ec086b6..dcdd62a108 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1371,7 +1371,6 @@ source:
 - cpukit/score/src/condition.c
 - cpukit/score/src/configstackspacesize.c
 - cpukit/score/src/corebarrier.c
-- cpukit/score/src/corebarrierrelease.c
 - cpukit/score/src/corebarrierwait.c
 - cpukit/score/src/coremsgbroadcast.c
 - cpukit/score/src/coremsg.c
2.26.2
