[PATCH] rtems: Move rtems_task_priority definition
Mon Feb 22 08:44:16 UTC 2021
This type is not only used by Task Manager directives.  This is a
preparation to move the rtems_scheduler_*() directives from
<rtems/rtems/tasks.h> to a new <rtems/rtems/scheduler.h>.
 cpukit/include/rtems/rtems/sem.h   |  1 -
 cpukit/include/rtems/rtems/timer.h |  1 -
 cpukit/include/rtems/rtems/types.h | 13 +++++++++++--
 3 files changed, 11 insertions(+), 4 deletions(-)
diff --git a/cpukit/include/rtems/rtems/sem.h b/cpukit/include/rtems/rtems/sem.h
index 7e4780cebf..74d0ab45a3 100644
--- a/cpukit/include/rtems/rtems/sem.h
+++ b/cpukit/include/rtems/rtems/sem.h
@@ -58,7 +58,6 @@
 #include <rtems/rtems/attr.h>
 #include <rtems/rtems/options.h>
-#include <rtems/rtems/tasks.h>
 #ifdef __cplusplus
diff --git a/cpukit/include/rtems/rtems/timer.h b/cpukit/include/rtems/rtems/timer.h
index 87f18b3581..4593feecf3 100644
--- a/cpukit/include/rtems/rtems/timer.h
+++ b/cpukit/include/rtems/rtems/timer.h
@@ -59,7 +59,6 @@
 #include <stddef.h>
 #include <rtems/score/watchdogticks.h>
diff --git a/cpukit/include/rtems/rtems/types.h b/cpukit/include/rtems/rtems/types.h
index a058eedea1..bf656b623e 100644
--- a/cpukit/include/rtems/rtems/types.h
+++ b/cpukit/include/rtems/rtems/types.h
@@ -7,8 +7,8 @@
- * Copyright (C) 2009, 2020 embedded brains GmbH (http://www.embedded-brains.de)
- * Copyright (C) 2006, 2008 On-Line Applications Research Corporation (OAR)
+ * Copyright (C) 2009, 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 1988, 2017 On-Line Applications Research Corporation (OAR)
  * modification, are permitted provided that the following conditions
@@ -254,6 +254,15 @@ typedef uint32_t rtems_name;
   typedef MP_packet_Prefix rtems_packet_prefix;
 #endif
+/* Generated from spec:/rtems/type/if/priority */
+ * @ingroup RTEMSAPIClassicTypes
+ * @brief This integer type represents task priorities of the Classic API.
+typedef uint32_t rtems_task_priority;
 /* Generated from spec:/rtems/type/if/time-of-day */
2.26.2
