[PATCH v3 0/1] Resubmission of patch previously submitted Sept 2020
Chris Johns
chrisj at rtems.org
Mon Feb 22 21:23:12 UTC 2021
Hi James,
Thanks for the patch. It is close. Could I ask if all the source files from you
please be updated to the latest template with the 2-clause BSD license? It will
say us having to include them in the sweep when we get to that task. I see a mix
in the files provided.
Thanks
On 21/2/21 8:29 pm, James Fitzsimons wrote:
> This patch adds driver support for the eQEP (enhanced Quadrature Encoder Pulse)
> module within each of the PWMSS units in the AM335x. The eQEP module is used for
> hardware decoding of rotrary encoders, motor encoders etc.
> Because the PWMSS module includes several components some of the existing code in
> the pwm driver could be reused. To make this common I have added a pwmss.h header
> and moved some of the pwmss specific defines and enum to this file. The pwmss.c
> file contains a refactored (simplified) version of the clock configuration
> method that was previously in the pwm.c file. The pwmss_module_clk_config will
> now be shared by both the pwm and eqep drivers (and eventually the ecap driver if
> that is ever added).
> The approach taken with the qep.h header was to move some of the qep specific
> defines from the am335x.h header to this file. They are specific to the qep
> function and would likely never be referenced by anything other than this driver.
> Doing this keeps these definitions with the driver code and reduces clutter in
> am335x.h header.
> The driver supports two primary modes of operation. A polled mode (which is the
> default mode), and an interrupt event driven mode.
> This patch includes the following revisions after feedback from Chris Johns:
> - improved documentation
> - addition of void* user argument to interrupt callback
> - addition of position value arg to interrupt callback
> James Fitzsimons (1):
> Adding QEP driver support to BeagleBoneBlack BSP
> bsps/arm/beagle/headers.am | 2 +
> bsps/arm/beagle/include/bsp/bbb-pwm.h | 11 -
> bsps/arm/beagle/include/bsp/pwmss.h | 54 +++
> bsps/arm/beagle/include/bsp/qep.h | 382 ++++++++++++++++++++
> bsps/arm/beagle/pwm/pwm.c | 60 +---
> bsps/arm/beagle/pwmss/pwmss.c | 64 ++++
> bsps/arm/beagle/qep/qep.c | 445 ++++++++++++++++++++++++
> c/src/lib/libbsp/arm/beagle/Makefile.am | 6 +
> spec/build/bsps/arm/beagle/obj.yml | 5 +-
> 9 files changed, 959 insertions(+), 70 deletions(-)
> create mode 100644 bsps/arm/beagle/include/bsp/pwmss.h
> create mode 100644 bsps/arm/beagle/include/bsp/qep.h
> create mode 100644 bsps/arm/beagle/pwmss/pwmss.c
> create mode 100644 bsps/arm/beagle/qep/qep.c
