[PATCH v3 0/1] Resubmission of patch previously submitted Sept 2020
James Fitzsimons
james.fitzsimons at gmail.com
Mon Feb 22 19:12:06 UTC 2021
Thanks Christian,
That's much appreciated.
Cheers,
James
On Tue, 23 Feb 2021 at 08:01, Christian Mauderer <oss at c-mauderer.de> wrote:
> Hello James,
> thanks for the patch and sorry that it get lost on the first submission.
> The patch compiles fine and it doesn't seem to change interfaces a lot.
> So I would say it is OK. I'll give it two or three more days of review
> before pushing it.
> Please remind me again in a week in case I forget to push it.
> Best regards
> Christian
> On 21/02/2021 10:29, James Fitzsimons wrote:
> > This patch adds driver support for the eQEP (enhanced Quadrature Encoder
> Pulse)
> > module within each of the PWMSS units in the AM335x. The eQEP module is
> used for
> > hardware decoding of rotrary encoders, motor encoders etc.
> > Because the PWMSS module includes several components some of the
> existing code in
> > the pwm driver could be reused. To make this common I have added a
> pwmss.h header
> > and moved some of the pwmss specific defines and enum to this file. The
> pwmss.c
> > file contains a refactored (simplified) version of the clock
> configuration
> > method that was previously in the pwm.c file. The
> pwmss_module_clk_config will
> > now be shared by both the pwm and eqep drivers (and eventually the ecap
> driver if
> > that is ever added).
> > The approach taken with the qep.h header was to move some of the qep
> specific
> > defines from the am335x.h header to this file. They are specific to the
> qep
> > function and would likely never be referenced by anything other than
> this driver.
> > Doing this keeps these definitions with the driver code and reduces
> clutter in
> > am335x.h header.
> > The driver supports two primary modes of operation. A polled mode (which
> is the
> > default mode), and an interrupt event driven mode.
> > This patch includes the following revisions after feedback from Chris
> Johns:
> > - improved documentation
> > - addition of void* user argument to interrupt callback
> > - addition of position value arg to interrupt callback
> > James Fitzsimons (1):
> > Adding QEP driver support to BeagleBoneBlack BSP
> > bsps/arm/beagle/headers.am | 2 +
> > bsps/arm/beagle/include/bsp/bbb-pwm.h | 11 -
> > bsps/arm/beagle/include/bsp/pwmss.h | 54 +++
> > bsps/arm/beagle/include/bsp/qep.h | 382 ++++++++++++++++++++
> > bsps/arm/beagle/pwm/pwm.c | 60 +---
> > bsps/arm/beagle/pwmss/pwmss.c | 64 ++++
> > bsps/arm/beagle/qep/qep.c | 445 ++++++++++++++++++++++++
> > c/src/lib/libbsp/arm/beagle/Makefile.am | 6 +
> > spec/build/bsps/arm/beagle/obj.yml | 5 +-
> > 9 files changed, 959 insertions(+), 70 deletions(-)
> > create mode 100644 bsps/arm/beagle/include/bsp/pwmss.h
> > create mode 100644 bsps/arm/beagle/include/bsp/qep.h
> > create mode 100644 bsps/arm/beagle/pwmss/pwmss.c
> > create mode 100644 bsps/arm/beagle/qep/qep.c
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210223/04ef0daf/attachment.html>
