[PATCH 2/2] score: Fix _Stack_Extend_size()
Sebastian Huber
Fri Feb 26 13:46:21 UTC 2021
Check for an integer overflow. Add a validation test for task create
errors.
cpukit/include/rtems/score/stackimpl.h | 28 +-
.../testsuites/validation/validation-0.yml | 1 +
testsuites/validation/tc-task-create-errors.c | 3180 +++++++++++++++++
3 files changed, 3202 insertions(+), 7 deletions(-)
create mode 100644 testsuites/validation/tc-task-create-errors.c
diff --git a/cpukit/include/rtems/score/stackimpl.h b/cpukit/include/rtems/score/stackimpl.h
index 4b014e334d..43b7c8151e 100644
--- a/cpukit/include/rtems/score/stackimpl.h
+++ b/cpukit/include/rtems/score/stackimpl.h
@@ -119,28 +119,42 @@ RTEMS_INLINE_ROUTINE size_t _Stack_Ensure_minimum (
- * @brief Extend the stack size to account for additional data structures
- * allocated in the stack area of a thread.
+ * @brief Extends the stack size to account for additional data structures
+ * allocated in the thread storage area.
- * @param stack_size The stack size.
- * @param is_fp Indicates if the stack is for a floating-point thread.
+ * @param stack_size is the stack size.
+ * @param is_fp shall be true, if the stack is for a floating-point thread,
+ * otherwise it shall be false.
- * @return The extended stack size.
+ * @return Returns the extended stack size.
RTEMS_INLINE_ROUTINE size_t _Stack_Extend_size(
size_t stack_size,
bool is_fp
+ size_t extra_size;
+ extra_size = _TLS_Get_allocation_size();
#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
if ( is_fp ) {
- stack_size += CONTEXT_FP_SIZE;
+ /* This addition cannot overflow since the TLS size cannot be that large */
+ extra_size += CONTEXT_FP_SIZE;
#else
(void) is_fp;
#endif
- stack_size += _TLS_Get_allocation_size();
+ stack_size += extra_size;
+ if ( stack_size < extra_size ) {
+ * In case of an unsigned integer overflow, saturate at the maximum value.
+ stack_size = SIZE_MAX;
return stack_size;
diff --git a/spec/build/testsuites/validation/validation-0.yml b/spec/build/testsuites/validation/validation-0.yml
index 02e5744145..653e34824e 100644
--- a/spec/build/testsuites/validation/validation-0.yml
+++ b/spec/build/testsuites/validation/validation-0.yml
@@ -20,6 +20,7 @@ source:
- testsuites/validation/tc-signal-catch.c
- testsuites/validation/tc-signal-send.c
- testsuites/validation/tc-task-construct-errors.c
+- testsuites/validation/tc-task-create-errors.c
- testsuites/validation/ts-validation-0.c
stlib: []
target: testsuites/validation/ts-validation-0.exe
diff --git a/testsuites/validation/tc-task-create-errors.c b/testsuites/validation/tc-task-create-errors.c
new file mode 100644
index 0000000000..39b9c0cc28
--- /dev/null
+++ b/testsuites/validation/tc-task-create-errors.c
@@ -0,0 +1,3180 @@
+ * @file
+ * @ingroup RTEMSTestCaseRtemsTaskReqCreateErrors
+ * Copyright (C) 2020, 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * This file is part of the RTEMS quality process and was automatically
+ * generated. If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual. The manual is provided as a part of
+ * a release. For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <string.h>
+#include <rtems/score/apimutex.h>
+#include <rtems/score/threadimpl.h>
+#include <rtems/test.h>
+ * @defgroup RTEMSTestCaseRtemsTaskReqCreateErrors \
+ * spec:/rtems/task/req/create-errors
+ * @ingroup RTEMSTestSuiteTestsuitesValidation0
+typedef enum {
+ RtemsTaskReqCreateErrors_Pre_Id_Valid,
+ RtemsTaskReqCreateErrors_Pre_Id_Null,
+ RtemsTaskReqCreateErrors_Pre_Id_NA
+} RtemsTaskReqCreateErrors_Pre_Id;
+typedef enum {
+ RtemsTaskReqCreateErrors_Pre_Name_Valid,
+ RtemsTaskReqCreateErrors_Pre_Name_Inv,
+ RtemsTaskReqCreateErrors_Pre_Name_NA
+} RtemsTaskReqCreateErrors_Pre_Name;
+typedef enum {
+ RtemsTaskReqCreateErrors_Pre_SysTsk_Yes,
+ RtemsTaskReqCreateErrors_Pre_SysTsk_No,
+ RtemsTaskReqCreateErrors_Pre_SysTsk_NA
+} RtemsTaskReqCreateErrors_Pre_SysTsk;
+typedef enum {
+ RtemsTaskReqCreateErrors_Pre_Prio_Valid,
+ RtemsTaskReqCreateErrors_Pre_Prio_Zero,
+ RtemsTaskReqCreateErrors_Pre_Prio_Inv,
+ RtemsTaskReqCreateErrors_Pre_Prio_NA
+} RtemsTaskReqCreateErrors_Pre_Prio;
+typedef enum {
+ RtemsTaskReqCreateErrors_Pre_Free_Yes,
+ RtemsTaskReqCreateErrors_Pre_Free_No,
+ RtemsTaskReqCreateErrors_Pre_Free_NA
+} RtemsTaskReqCreateErrors_Pre_Free;
+typedef enum {
+ RtemsTaskReqCreateErrors_Pre_Stack_Normal,
+ RtemsTaskReqCreateErrors_Pre_Stack_Small,
+ RtemsTaskReqCreateErrors_Pre_Stack_Huge,
+ RtemsTaskReqCreateErrors_Pre_Stack_NA
+} RtemsTaskReqCreateErrors_Pre_Stack;
+typedef enum {
+ RtemsTaskReqCreateErrors_Pre_Ext_Ok,
+ RtemsTaskReqCreateErrors_Pre_Ext_Err,
+ RtemsTaskReqCreateErrors_Pre_Ext_NA
+} RtemsTaskReqCreateErrors_Pre_Ext;
+typedef enum {
+ RtemsTaskReqCreateErrors_Post_Status_Ok,
+ RtemsTaskReqCreateErrors_Post_Status_InvAddr,
+ RtemsTaskReqCreateErrors_Post_Status_InvName,
+ RtemsTaskReqCreateErrors_Post_Status_InvPrio,
+ RtemsTaskReqCreateErrors_Post_Status_TooMany,
+ RtemsTaskReqCreateErrors_Post_Status_Unsat,
+ RtemsTaskReqCreateErrors_Post_Status_NA
+} RtemsTaskReqCreateErrors_Post_Status;
+typedef enum {
+ RtemsTaskReqCreateErrors_Post_Name_Valid,
+ RtemsTaskReqCreateErrors_Post_Name_Invalid,
+ RtemsTaskReqCreateErrors_Post_Name_NA
+} RtemsTaskReqCreateErrors_Post_Name;
+typedef enum {
+ RtemsTaskReqCreateErrors_Post_IdValue_Assigned,
+ RtemsTaskReqCreateErrors_Post_IdValue_Unchanged,
+ RtemsTaskReqCreateErrors_Post_IdValue_NA
+} RtemsTaskReqCreateErrors_Post_IdValue;
+typedef enum {
+ RtemsTaskReqCreateErrors_Post_CreateExt_Yes,
+ RtemsTaskReqCreateErrors_Post_CreateExt_No,
+ RtemsTaskReqCreateErrors_Post_CreateExt_NA
+} RtemsTaskReqCreateErrors_Post_CreateExt;
+typedef enum {
+ RtemsTaskReqCreateErrors_Post_DelExt_Yes,
+ RtemsTaskReqCreateErrors_Post_DelExt_No,
+ RtemsTaskReqCreateErrors_Post_DelExt_NA
+} RtemsTaskReqCreateErrors_Post_DelExt;
+ * @brief Test context for spec:/rtems/task/req/create-errors test case.
+typedef struct {
+ rtems_status_code status;
+ rtems_id *id;
+ rtems_id id_value;
+ bool create_extension_status;
+ uint32_t create_extension_calls;
+ uint32_t delete_extension_calls;
+ rtems_name name;
+ rtems_task_priority initial_priority;
+ size_t stack_size;
+ rtems_attribute attributes;
+ rtems_id extension_id;
+ void *seized_objects;
+ * @brief This member defines the pre-condition states for the next action.
+ size_t pcs[ 7 ];
+ * @brief This member indicates if the test action loop is currently
+ * executed.
+ bool in_action_loop;
+} RtemsTaskReqCreateErrors_Context;
+static RtemsTaskReqCreateErrors_Context
+ RtemsTaskReqCreateErrors_Instance;
+static const char * const RtemsTaskReqCreateErrors_PreDesc_Id[] = {
+ "Valid",
+ "Null",
+ "NA"
+static const char * const RtemsTaskReqCreateErrors_PreDesc_Name[] = {
+ "Valid",
+ "Inv",
+ "NA"
+static const char * const RtemsTaskReqCreateErrors_PreDesc_SysTsk[] = {
+ "Yes",
+ "No",
+ "NA"
+static const char * const RtemsTaskReqCreateErrors_PreDesc_Prio[] = {
+ "Valid",
+ "Zero",
+ "Inv",
+ "NA"
+static const char * const RtemsTaskReqCreateErrors_PreDesc_Free[] = {
+ "Yes",
+ "No",
+ "NA"
+static const char * const RtemsTaskReqCreateErrors_PreDesc_Stack[] = {
+ "Normal",
+ "Small",
+ "Huge",
+ "NA"
+static const char * const RtemsTaskReqCreateErrors_PreDesc_Ext[] = {
+ "Ok",
+ "Err",
+ "NA"
+static const char * const * const RtemsTaskReqCreateErrors_PreDesc[] = {
+ RtemsTaskReqCreateErrors_PreDesc_Id,
+ RtemsTaskReqCreateErrors_PreDesc_Name,
+ RtemsTaskReqCreateErrors_PreDesc_SysTsk,
+ RtemsTaskReqCreateErrors_PreDesc_Prio,
+ RtemsTaskReqCreateErrors_PreDesc_Free,
+ RtemsTaskReqCreateErrors_PreDesc_Stack,
+ RtemsTaskReqCreateErrors_PreDesc_Ext,
+ NULL
+#define NAME rtems_build_name( 'T', 'E', 'S', 'T' )
+#define INVALID_ID 0xffffffff
+typedef RtemsTaskReqCreateErrors_Context Context;
+static rtems_status_code Create( void *arg, uint32_t *id )
+ Context *ctx;
+ rtems_status_code sc;
+ ctx = arg;
+ create_extension_status = ctx->create_extension_status;
+ ctx->create_extension_status = true;
+ sc = rtems_task_create(
+ rtems_build_name( 'S', 'I', 'Z', 'E' ),
+ 1,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ id
+ ctx->create_extension_status = create_extension_status;
+ return sc;
+static bool ThreadCreate( rtems_tcb *executing, rtems_tcb *created )
+ (void) executing;
+ (void) created;
+ ++RtemsTaskReqCreateErrors_Instance.create_extension_calls;
+ return RtemsTaskReqCreateErrors_Instance.create_extension_status;
+static void ThreadDelete( rtems_tcb *executing, rtems_tcb *deleted )
+ (void) executing;
+ (void) deleted;
+ ++RtemsTaskReqCreateErrors_Instance.delete_extension_calls;
+static const rtems_extensions_table extensions = {
+ .thread_create = ThreadCreate,
+ .thread_delete = ThreadDelete
+static void RtemsTaskReqCreateErrors_Pre_Id_Prepare(
+ RtemsTaskReqCreateErrors_Context *ctx,
+ RtemsTaskReqCreateErrors_Pre_Id state
+ switch ( state ) {
+ case RtemsTaskReqCreateErrors_Pre_Id_Valid: {
+ ctx->id = &ctx->id_value;
+ break;
+ case RtemsTaskReqCreateErrors_Pre_Id_Null: {
+ ctx->id = NULL;
+ break;
+ case RtemsTaskReqCreateErrors_Pre_Id_NA:
+ break;
+static void RtemsTaskReqCreateErrors_Pre_Name_Prepare(
+ RtemsTaskReqCreateErrors_Pre_Name state
+ case RtemsTaskReqCreateErrors_Pre_Name_Valid: {
+ ctx->name = NAME;
+ break;
+ case RtemsTaskReqCreateErrors_Pre_Name_Inv: {
+ ctx->name = 0;
+ break;
+ case RtemsTaskReqCreateErrors_Pre_Name_NA:
+ break;
+static void RtemsTaskReqCreateErrors_Pre_SysTsk_Prepare(
+ RtemsTaskReqCreateErrors_Pre_SysTsk state
+ case RtemsTaskReqCreateErrors_Pre_SysTsk_Yes: {
+ ctx->attributes = RTEMS_SYSTEM_TASK;
+ break;
+ case RtemsTaskReqCreateErrors_Pre_SysTsk_No: {
+ ctx->attributes = RTEMS_DEFAULT_ATTRIBUTES;
+ break;
+ case RtemsTaskReqCreateErrors_Pre_SysTsk_NA:
+ break;
+static void RtemsTaskReqCreateErrors_Pre_Prio_Prepare(
+ RtemsTaskReqCreateErrors_Pre_Prio state
+ case RtemsTaskReqCreateErrors_Pre_Prio_Valid: {
+ ctx->initial_priority = 254;
+ break;
+ case RtemsTaskReqCreateErrors_Pre_Prio_Zero: {
+ ctx->initial_priority = 0;
+ break;
+ case RtemsTaskReqCreateErrors_Pre_Prio_Inv: {
+ ctx->initial_priority = 0xffffffff;
+ break;
+ case RtemsTaskReqCreateErrors_Pre_Prio_NA:
+ break;
+static void RtemsTaskReqCreateErrors_Pre_Free_Prepare(
+ RtemsTaskReqCreateErrors_Pre_Free state
+ case RtemsTaskReqCreateErrors_Pre_Free_Yes: {
+ /* Nothing to do */
+ break;
+ case RtemsTaskReqCreateErrors_Pre_Free_No: {
+ ctx->seized_objects = T_seize_objects( Create, ctx );
+ break;
+ case RtemsTaskReqCreateErrors_Pre_Free_NA:
+ break;
+static void RtemsTaskReqCreateErrors_Pre_Stack_Prepare(
+ RtemsTaskReqCreateErrors_Pre_Stack state
+ case RtemsTaskReqCreateErrors_Pre_Stack_Normal: {
+ ctx->stack_size = RTEMS_MINIMUM_STACK_SIZE;
+ break;
+ case RtemsTaskReqCreateErrors_Pre_Stack_Small: {
+ ctx->stack_size = 0;
+ break;
+ case RtemsTaskReqCreateErrors_Pre_Stack_Huge: {
+ ctx->stack_size = SIZE_MAX;
+ break;
+ case RtemsTaskReqCreateErrors_Pre_Stack_NA:
+ break;
+static void RtemsTaskReqCreateErrors_Pre_Ext_Prepare(
+ RtemsTaskReqCreateErrors_Pre_Ext state
+ case RtemsTaskReqCreateErrors_Pre_Ext_Ok: {
+ break;
+ case RtemsTaskReqCreateErrors_Pre_Ext_Err: {
+ ctx->create_extension_status = false;
+ break;
+ case RtemsTaskReqCreateErrors_Pre_Ext_NA:
+ break;
+static void RtemsTaskReqCreateErrors_Post_Status_Check(
+ RtemsTaskReqCreateErrors_Post_Status state
+ case RtemsTaskReqCreateErrors_Post_Status_Ok: {
+ T_rsc_success( ctx->status );
+ break;
+ case RtemsTaskReqCreateErrors_Post_Status_InvAddr: {
+ T_rsc( ctx->status, RTEMS_INVALID_ADDRESS );
+ break;
+ case RtemsTaskReqCreateErrors_Post_Status_InvName: {
+ T_rsc( ctx->status, RTEMS_INVALID_NAME );
+ break;
+ case RtemsTaskReqCreateErrors_Post_Status_InvPrio: {
+ T_rsc( ctx->status, RTEMS_INVALID_PRIORITY );
+ break;
+ case RtemsTaskReqCreateErrors_Post_Status_TooMany: {
+ T_rsc( ctx->status, RTEMS_TOO_MANY );
+ break;
+ case RtemsTaskReqCreateErrors_Post_Status_Unsat: {
+ T_rsc( ctx->status, RTEMS_UNSATISFIED );
+ break;
+ case RtemsTaskReqCreateErrors_Post_Status_NA:
+ break;
+static void RtemsTaskReqCreateErrors_Post_Name_Check(
+ RtemsTaskReqCreateErrors_Post_Name state
+ rtems_id id;
+ case RtemsTaskReqCreateErrors_Post_Name_Valid: {
+ id = 0;
+ sc = rtems_task_ident( NAME, RTEMS_SEARCH_LOCAL_NODE, &id );
+ T_rsc_success( sc );
+ T_eq_u32( id, ctx->id_value );
+ break;
+ case RtemsTaskReqCreateErrors_Post_Name_Invalid: {
+ T_rsc( sc, RTEMS_INVALID_NAME );
+ break;
+ case RtemsTaskReqCreateErrors_Post_Name_NA:
+ break;
+static void RtemsTaskReqCreateErrors_Post_IdValue_Check(
+ RtemsTaskReqCreateErrors_Post_IdValue state
+ case RtemsTaskReqCreateErrors_Post_IdValue_Assigned: {
+ T_eq_ptr( ctx->id, &ctx->id_value );
+ T_ne_u32( ctx->id_value, INVALID_ID );
+ break;
+ case RtemsTaskReqCreateErrors_Post_IdValue_Unchanged: {
+ T_eq_u32( ctx->id_value, INVALID_ID );
+ break;
+ case RtemsTaskReqCreateErrors_Post_IdValue_NA:
+ break;
+static void RtemsTaskReqCreateErrors_Post_CreateExt_Check(
+ RtemsTaskReqCreateErrors_Post_CreateExt state
+ case RtemsTaskReqCreateErrors_Post_CreateExt_Yes: {
+ T_eq_u32( ctx->create_extension_calls, 1 );
+ break;
+ case RtemsTaskReqCreateErrors_Post_CreateExt_No: {
+ T_eq_u32( ctx->create_extension_calls, 0 );
+ break;
+ case RtemsTaskReqCreateErrors_Post_CreateExt_NA:
+ break;
+static void RtemsTaskReqCreateErrors_Post_DelExt_Check(
+ RtemsTaskReqCreateErrors_Post_DelExt state
+ case RtemsTaskReqCreateErrors_Post_DelExt_Yes: {
+ T_eq_u32( ctx->delete_extension_calls, 1 );
+ break;
+ case RtemsTaskReqCreateErrors_Post_DelExt_No: {
+ T_eq_u32( ctx->delete_extension_calls, 0 );
+ break;
+ case RtemsTaskReqCreateErrors_Post_DelExt_NA:
+ break;
+static void RtemsTaskReqCreateErrors_Setup(
+ sc = rtems_extension_create(
+ rtems_build_name( 'T', 'E', 'X', 'T' ),
+ &extensions,
+ &ctx->extension_id
+static void RtemsTaskReqCreateErrors_Setup_Wrap( void *arg )
+ RtemsTaskReqCreateErrors_Context *ctx;
+ ctx = arg;
+ ctx->in_action_loop = false;
+ RtemsTaskReqCreateErrors_Setup( ctx );
+static void RtemsTaskReqCreateErrors_Teardown(
+ sc = rtems_extension_delete( ctx->extension_id );
+static void RtemsTaskReqCreateErrors_Teardown_Wrap( void *arg )
+ ctx = arg;
+ RtemsTaskReqCreateErrors_Teardown( ctx );
+static size_t RtemsTaskReqCreateErrors_Scope( void *arg, char *buf, size_t n )
+ ctx = arg;
+ if ( ctx->in_action_loop ) {
+ return T_get_scope( RtemsTaskReqCreateErrors_PreDesc, buf, n, ctx->pcs );
+ return 0;
+static T_fixture RtemsTaskReqCreateErrors_Fixture = {
+ .setup = RtemsTaskReqCreateErrors_Setup_Wrap,
+ .stop = NULL,
+ .teardown = RtemsTaskReqCreateErrors_Teardown_Wrap,
+ .scope = RtemsTaskReqCreateErrors_Scope,
+ .initial_context = &RtemsTaskReqCreateErrors_Instance
+static const uint8_t RtemsTaskReqCreateErrors_TransitionMap[][ 5 ] = {
+static const struct {
+ uint8_t Skip : 1;
+ uint8_t Pre_Id_NA : 1;
+ uint8_t Pre_Name_NA : 1;
+ uint8_t Pre_SysTsk_NA : 1;
+ uint8_t Pre_Prio_NA : 1;
+ uint8_t Pre_Free_NA : 1;
+ uint8_t Pre_Stack_NA : 1;
+ uint8_t Pre_Ext_NA : 1;
+} RtemsTaskReqCreateErrors_TransitionInfo[] = {
+ 0, 0, 0, 0, 0, 0, 0, 0
+static void RtemsTaskReqCreateErrors_Prepare(
+ _RTEMS_Lock_allocator();
+ _Thread_Kill_zombies();
+ _RTEMS_Unlock_allocator();
+ ctx->id_value = INVALID_ID;
+static void RtemsTaskReqCreateErrors_Action(
+ ctx->create_extension_calls = 0;
+ ctx->delete_extension_calls = 0;
+ ctx->status = rtems_task_create(
+ ctx->name,
+ ctx->initial_priority,
+ ctx->stack_size,
+ ctx->attributes,
+ ctx->id
+static void RtemsTaskReqCreateErrors_Cleanup(
+ if ( ctx->id_value != INVALID_ID ) {
+ sc = rtems_task_delete( ctx->id_value );
+ T_surrender_objects( &ctx->seized_objects, rtems_task_delete );
+ * @fn void T_case_body_RtemsTaskReqCreateErrors( void )
+T_TEST_CASE_FIXTURE(
+ RtemsTaskReqCreateErrors,
+ &RtemsTaskReqCreateErrors_Fixture
+ size_t index;
+ ctx = T_fixture_context();
+ ctx->in_action_loop = true;
+ index = 0;
+ for (
+ ctx->pcs[ 0 ] = RtemsTaskReqCreateErrors_Pre_Id_Valid;
+ ctx->pcs[ 0 ] < RtemsTaskReqCreateErrors_Pre_Id_NA;
+ ++ctx->pcs[ 0 ]
+ if ( RtemsTaskReqCreateErrors_TransitionInfo[ index ].Pre_Id_NA ) {
+ ctx->pcs[ 0 ] = RtemsTaskReqCreateErrors_Pre_Id_NA;
+ index += ( RtemsTaskReqCreateErrors_Pre_Id_NA - 1 )
+ * RtemsTaskReqCreateErrors_Pre_Name_NA
+ * RtemsTaskReqCreateErrors_Pre_SysTsk_NA
+ * RtemsTaskReqCreateErrors_Pre_Prio_NA
+ * RtemsTaskReqCreateErrors_Pre_Free_NA
+ * RtemsTaskReqCreateErrors_Pre_Stack_NA
+ * RtemsTaskReqCreateErrors_Pre_Ext_NA;
+ for (
+ ctx->pcs[ 1 ] = RtemsTaskReqCreateErrors_Pre_Name_Valid;
+ ctx->pcs[ 1 ] < RtemsTaskReqCreateErrors_Pre_Name_NA;
+ ++ctx->pcs[ 1 ]
+ if ( RtemsTaskReqCreateErrors_TransitionInfo[ index ].Pre_Name_NA ) {
+ ctx->pcs[ 1 ] = RtemsTaskReqCreateErrors_Pre_Name_NA;
+ index += ( RtemsTaskReqCreateErrors_Pre_Name_NA - 1 )
+ for (
+ ctx->pcs[ 2 ] = RtemsTaskReqCreateErrors_Pre_SysTsk_Yes;
+ ctx->pcs[ 2 ] < RtemsTaskReqCreateErrors_Pre_SysTsk_NA;
+ ++ctx->pcs[ 2 ]
+ if ( RtemsTaskReqCreateErrors_TransitionInfo[ index ].Pre_SysTsk_NA ) {
+ ctx->pcs[ 2 ] = RtemsTaskReqCreateErrors_Pre_SysTsk_NA;
+ index += ( RtemsTaskReqCreateErrors_Pre_SysTsk_NA - 1 )
+ for (
+ ctx->pcs[ 3 ] = RtemsTaskReqCreateErrors_Pre_Prio_Valid;
+ ctx->pcs[ 3 ] < RtemsTaskReqCreateErrors_Pre_Prio_NA;
+ ++ctx->pcs[ 3 ]
+ if ( RtemsTaskReqCreateErrors_TransitionInfo[ index ].Pre_Prio_NA ) {
+ ctx->pcs[ 3 ] = RtemsTaskReqCreateErrors_Pre_Prio_NA;
+ index += ( RtemsTaskReqCreateErrors_Pre_Prio_NA - 1 )
+ for (
+ ctx->pcs[ 4 ] = RtemsTaskReqCreateErrors_Pre_Free_Yes;
+ ctx->pcs[ 4 ] < RtemsTaskReqCreateErrors_Pre_Free_NA;
+ ++ctx->pcs[ 4 ]
+ if ( RtemsTaskReqCreateErrors_TransitionInfo[ index ].Pre_Free_NA ) {
+ ctx->pcs[ 4 ] = RtemsTaskReqCreateErrors_Pre_Free_NA;
+ index += ( RtemsTaskReqCreateErrors_Pre_Free_NA - 1 )
+ for (
+ ctx->pcs[ 5 ] = RtemsTaskReqCreateErrors_Pre_Stack_Normal;
+ ctx->pcs[ 5 ] < RtemsTaskReqCreateErrors_Pre_Stack_NA;
+ ++ctx->pcs[ 5 ]
+ if ( RtemsTaskReqCreateErrors_TransitionInfo[ index ].Pre_Stack_NA ) {
+ ctx->pcs[ 5 ] = RtemsTaskReqCreateErrors_Pre_Stack_NA;
+ index += ( RtemsTaskReqCreateErrors_Pre_Stack_NA - 1 )
+ for (
+ ctx->pcs[ 6 ] = RtemsTaskReqCreateErrors_Pre_Ext_Ok;
+ ctx->pcs[ 6 ] < RtemsTaskReqCreateErrors_Pre_Ext_NA;
+ ++ctx->pcs[ 6 ]
+ if ( RtemsTaskReqCreateErrors_TransitionInfo[ index ].Pre_Ext_NA ) {
+ ctx->pcs[ 6 ] = RtemsTaskReqCreateErrors_Pre_Ext_NA;
+ index += ( RtemsTaskReqCreateErrors_Pre_Ext_NA - 1 );
+ if ( RtemsTaskReqCreateErrors_TransitionInfo[ index ].Skip ) {
+ ++index;
+ continue;
+ RtemsTaskReqCreateErrors_Prepare( ctx );
+ RtemsTaskReqCreateErrors_Pre_Id_Prepare( ctx, ctx->pcs[ 0 ] );
+ RtemsTaskReqCreateErrors_Pre_Name_Prepare(
+ ctx,
+ ctx->pcs[ 1 ]
+ RtemsTaskReqCreateErrors_Pre_SysTsk_Prepare(
+ ctx,
+ ctx->pcs[ 2 ]
+ RtemsTaskReqCreateErrors_Pre_Prio_Prepare(
+ ctx,
+ ctx->pcs[ 3 ]
+ RtemsTaskReqCreateErrors_Pre_Free_Prepare(
+ ctx,
+ ctx->pcs[ 4 ]
+ RtemsTaskReqCreateErrors_Pre_Stack_Prepare(
+ ctx,
+ ctx->pcs[ 5 ]
+ RtemsTaskReqCreateErrors_Pre_Ext_Prepare( ctx, ctx->pcs[ 6 ] );
+ RtemsTaskReqCreateErrors_Action( ctx );
+ RtemsTaskReqCreateErrors_Post_Status_Check(
+ ctx,
+ RtemsTaskReqCreateErrors_TransitionMap[ index ][ 0 ]
+ RtemsTaskReqCreateErrors_Post_Name_Check(
+ ctx,
+ RtemsTaskReqCreateErrors_TransitionMap[ index ][ 1 ]
+ RtemsTaskReqCreateErrors_Post_IdValue_Check(
+ ctx,
+ RtemsTaskReqCreateErrors_TransitionMap[ index ][ 2 ]
+ RtemsTaskReqCreateErrors_Post_CreateExt_Check(
+ ctx,
+ RtemsTaskReqCreateErrors_TransitionMap[ index ][ 3 ]
+ RtemsTaskReqCreateErrors_Post_DelExt_Check(
+ ctx,
+ RtemsTaskReqCreateErrors_TransitionMap[ index ][ 4 ]
+ RtemsTaskReqCreateErrors_Cleanup( ctx );
+ ++index;
2.26.2
