[PATCH 0/4] Fix Unchecked return value Coverity errors
Ryan Long
thisisryanlong at gmail.com
Fri Feb 26 21:34:43 UTC 2021
Hi,
Here are some fixes for a few of the "Unchecked return value" Coverity
errors. Mainly, I just created a variable to store the status code returned
from function calls and used the _Assert_Unused_variable_equals() macro
to assert that the call was successful. I also added a (void) in front
of the call to fsync() since that was getting flagged as well.
Thanks,
Ryan
Ryan Long (4):
printertask.c: Fix Unchecked return value (CID #1399710)
record-client.c: Fix Unchecked return value (CID #1456677)
getgrent.c: Fix Unchecked return value error (CID #1459004)
rtems-debugger-threads.c: Fix Unchecked return value error (CID
#1468688)
cpukit/libcsupport/src/getgrent.c | 4 +++-
cpukit/libcsupport/src/printertask.c | 9 ++++++---
cpukit/libdebugger/rtems-debugger-threads.c | 5 ++++-
cpukit/libtrace/record/record-client.c | 4 +++-
4 files changed, 16 insertions(+), 6 deletions(-)
1.8.3.1
